Results 351 to 360 of 1444
December 22nd, 2011 03:10 AM #351
- Apr 2008
- 6,235
December 22nd, 2011 06:53 PM #352
December 23rd, 2011 05:09 AM #353
- Apr 2008
- 6,235
December 23rd, 2011 11:03 PM #354
- Sep 2011
- 90
December 31st, 2011 06:41 PM #355TO ALL REVO OWNERS HAPPY NEW YEAR!!!
ingat sa pag gamit ng paputok.
Buti pa kayo makakaranas na naman ng putukan
samantalang ako dito na naman sa SG.
- Nov 2008
- 21
January 3rd, 2012 12:28 PM #356Happy New Year to All.
I spent my 5days forced leave just last week. Wala akong magawa kaya binuhos ko lahat ng oras sa Revo. I went to a mechanic for coolant change, checked/cleaned the breaks, change/repack bearing, engine wash, change differential and transmission oil, change oil and gasket.
Kaya lang, pag change ng break fluid which includes hanggang sa break linings na ginamitan ng vacuum, biglang may tumutunog sa rear whenever i step on the breaks. The mechanic bled the breaks twice same pa rin may tumutunog sa rear and mag slide ng almost an inch ang break. He advised me to let Toyota check it dahil nasa proportioning valve daw problem. I went to another mechanic without saying of the problem, pina bleeding ko lang ulit. biglang tumunog and naririnig nila na ang LSPV ang umiingay. I then went to a third mechanic, same pa rin but they tried to check baka ang pads sa rear left wheel ang umiingay but LSPV pa din ang findings nila. Puede ba yun? nag papalit lang ako ng break fluid biglang nasira LSPV? They explained na during pag change ng fluid, sumama ang mga dumi sa loob ng LSPV which served daw as a lubricant or stopper. pero nung malinis na meron nang hollow space na kinalalagyan ng dumi nuon. any advice? baka meron nang naka encounter ng ganitong problema.
7k ang LSPV sa toyota. Para talagang babae 'tong mga sasakyan, kung kelan mo inaasikaso ng husto saka mag lalambing, mag papa ksp.
Thanks.
January 4th, 2012 03:56 AM #357
^^Usually sir sa experience regarding diyan sa pag bleed ng brakes manually lang, hindi na kailangan ng vacuum, parang nagkaroon ng hangin dahil sa pag vacuum, try mo muna sir ibleed lahat including sa master, tapos gawin mo several times hangang sa makita mo ok na yung buga ng fluid sa bleeder
January 5th, 2012 10:37 PM #358
sa casa hindi nila drain brake fluid kasi baka magkaroon ng air bubbles..
i-bleed lang nila every 40T kms.. mga 2-3 brake fluids yata magagamit..
- Apr 2008
- 6,235
January 22nd, 2012 03:01 AM #359Hello again guys! Just wanna report that the time has come for me to change tires. So I replaced all of them with bigger 205/70/R14 GT Radial Classiro's for 3230 petot each. Napaka noticeable ang improvements. The ride height was noticeably higher, ride quality and most importantly handling has been improved as body roll in corners has been greatly reduced.
January 22nd, 2012 08:15 PM #360
