Results 1 to 10 of 12
- Apr 2008
- 6,235
February 28th, 2020 02:59 PM #2
- Dec 2019
- 2,073
February 28th, 2020 04:52 PM #3
March 5th, 2020 12:19 PM #5
March 5th, 2020 12:24 PM #6
- Apr 2008
- 6,235
March 5th, 2020 12:45 PM #7
- May 2014
- 1,318
March 5th, 2020 03:18 PM #9Sa automatics naman, if during acceleration mo talaga ang diin mo sa silinyador/accelarator tinutulak yung engine to go to 3000rpm, then that is how the car will shift.
Brother has a 1.6G Altis 2009 model A/T, kung controlled ang tapak mo, nagshift naman siya sa around 2000rpm range pero gradual acceleration lang ito (malumanay).
So, hindi masabi kung may iba bang issue yung sa iyo.
Iba ba tunug makina? Na parang imbalanced? Kasi nung sa kuya ko, may mali sa tunug ng makina. Turns out, isa sa spark plugs "dead" nung chineck. Nung panahon na iyon, kelangan din mga 2500rpm takbo namin bago talaga mag accelerate yung kotse, di mo makikita mag "Settle" yung rev during coasting sa 1500rpm range kasi kulang sa power na yung makina dahil sa isang "dead cylinder".
Again, pacheck mo if it really is a concern. Not going to immediately tell you to replace sparks and/or change oil.
Asa amin pa din ngayon yung Altis, back to "normal" ngayon.
EDIT: Going to what GTi said, Single VVTi lang itong Altis na carryover sa alam ko from the smaller body/lighter 2001 Altis pa. Later nung nagawa nila Dual VVTi yung Altis generation nito, medyo hindi na ganun kahirap yung makina to accelerate
- Apr 2008
- 6,235
March 5th, 2020 03:19 PM #10Yes, this is a relatively small displacement gasoline engine, and I would even say it is somewhat to be expected to be reaching 3000rpm to get going at a decent pace. If you prioritize fuel efficiency, try to keep the revs lower, preferably letting it shift at around 2000rpm. But otherwise, driving this way regularly will not negatively affect the engine. That is, after all, only halfway through its entire rev range.
Sent from my SM-G965N using Tapatalk
Tesla Philippines
