Quote Originally Posted by edwin9888 View Post
1.) Ask ko pang kung normal po ba umiinit ang wheels sa front?
sa long run mas mainit ang wheels sa harap compare sa likod normal po ba?
Heat from the mags, tires or both? The heat could be coming from the engine.
2.) Napansin ko po tuwing mag break ako, minsan po mahina lang nag bebreak po agad minsan po dapat idiin pa po paloob. Minsan nag sstandby ako sa traffic dumidiin sya paloob from normal break (nag iiba) parang ang feeling kakaon pa lang ng engine yung biglang lumalambot ang break pero mas lumalambot pa lalo. Normal po ba ito? bago naman po ang break pads.
Yung biglang bumabaon, napansin ko yan sa stand still traffic. It usually occurs in tandem with the aircon compressor shuttling bet. idles.
3.) Bakit po mahirap ma remote innova namin (open close door) dapat malapitan pa. bago naman po ang battery ng remote. Ano po ang pwede natin ma check dito?
Its a matter of your remote key having a clear line of sight with the transmitter inside the vehicle. As for mine, it varies. Sometimes even when you are a 2 meters away it won't function bec. I was pointing it down. It works well, when I'm pointing the key down from a 2 storey structure. Try pointing your remote key high and make sure there is a clear line of sight.
