Results 15,251 to 15,260 of 15472
November 23rd, 2023 11:57 AM #15251
RE: CVT
If its an appliance car and you're gonna dispose it in 10 years, it doesn't matter.
Plus if you're an a-hole, you won't change the CVT fluid on time and pass the problem to the next owner.
- Dec 2019
- 41
December 1st, 2023 04:00 PM #15252Hello po. I will be going to Petron tomorrow for our 4th year PMS and I would like to ask on what I should let them do with our car. Unfortunately, I couldn't find our manual's book to know what should be included in the 4th year PMS. What engine oil should we use? Should we change the brake pads already? Should we change the air filter?
Details about our car:
Car: Innova 2020 E AT
Distance travelled: ~16,000 kms
Last PMS: 2023 March 06 (done by Toyota)
Thank you in advance
- 53,883
December 1st, 2023 05:44 PM #15253i have my basics done at your friendly petron hecho-derecho oil and oil filter change promo, every 5000 km. i use ordinary mineral oil.
i see the air filter if it is too dirty or oil-stained; if so, i have it replaced. kung medyo malinis pa, i have it air-cleaned. yes, some folks may dis-agree.
i have my brake pads examined and have them replaced if already too thin. the front pads usually wear out twice as fast as the rear ones. the brake pads are user-dependent and not time- or km-dependent. i use whatever the banawe mechanic recommends.
consult your owner's manual, po, for the more comprehensive pms items.Last edited by dr. d; December 1st, 2023 at 05:50 PM.
- Dec 2019
- 41
December 1st, 2023 08:08 PM #15254Found the owner's manual.
Here's what to replace on the 4th year PMS:
1. Engine Oil
2. Engine Filter
3. Brake fluid
4. Rear Differential Oil
Do you know what engine oil to use? It says 0W-20, 5W-20, 5W-30, and 10W-30.
#PMS
December 1st, 2023 10:51 PM #15255
- Dec 2019
- 41
December 2nd, 2023 12:06 PM #15256Done with my change oil at Petron. 4,230 pesos for the 8L fully synthetic 5W-40. They told me that I don't have to change my brake fluid yet since the color is still clear. They also told me that the rear differential oil should be done by Toyota since newer Toyota cars have proprietary oil for it.
Additionally, they said that for the set of brake pads, it's going to be 1,500 pesos.
- 53,883
December 2nd, 2023 12:52 PM #15257
- Dec 2023
- 1
December 10th, 2023 09:44 AM #15258Hello po, just want to ask lang if may naka encounter na ng ganito and what you had done to solve it po. Yung Driver door lock di na naglolock pero kaya nya unlock lahat. pati na din yung sa key di na din naglolock but can unlock. Ok naman yung fuses chineck namin if putol.
Innova 2012 ver E, No keyless
- 53,883
December 10th, 2023 09:59 AM #15259
December 10th, 2023 10:31 AM #15260
Brake fluid is hygroscopic. It's advisable to change it every 2 years.
Sent from my SM-T970 using Tsikot Forums mobile app
