Results 301 to 310 of 15472
June 11th, 2011 11:57 AM #301
Open and empty out the glove compartment.
You will find that the glove compartment has a protusion on each side to keep it from falling out when open.
Push the side of the glove compartment to one side so the protusion is able to pop out.
Repeat for the other side.
The entire glove compartment will come off.
You will be able to see the ac filter on the lower right side of the cavity.
Its fitted in like a table drawer and you can simply pull it out to clean.
just did it and clean the same with a dish washing soap. the same was earlier discussed by sir ginnova, if i am not mistaken. credit goes to him.
June 11th, 2011 04:14 PM #302
- May 2007
- 5
June 11th, 2011 09:03 PM #303Guys need help, what could be the problem..
My ride is 06 d4d model E, once my aircon is ON my idle is a little bit shaky when my engine already heats up and when i'm changing gears for the first acceleration it rattles then the rattling is gone when my rpm is above 1T rpm...tnx need advice
- Dec 2009
- 304
June 11th, 2011 09:38 PM #304
- May 2007
- 5
June 11th, 2011 09:46 PM #305
June 11th, 2011 10:53 PM #306
Re: The free floormats from the dealers on newly acquired units.
We just got an E variant yesterday and the third row/cargo area did NOT come with a floormat. When we got our Fortuner in 2006, the floor matt on the third row was included.
June 12th, 2011 12:07 AM #307
Guys need help...
May problema / tunog ang front right shock absorber ko BUSTED na ata.... Ano po ang magandang ipalit ko dito? OEM or Other brand...
If other brand po how much? and what brand? para maging smooth and Innova natin.
Thanks....
- Feb 2011
- 35
June 12th, 2011 12:16 PM #308toyota dasma din ako, napakkakunat nila sa mga backjobs! better pa shouler mo na lang angh gastos at ipagawa sa labas lahat ng makita mong problems. complain ko din ang undercoat ko nung 1k pms ko ganun daw talaga. before that complain ko tint nila dahil magasgas ang gawa me participation pa daw ako. sa kanila naman lahat install yun. kahit na ba "free" yun dapat proper pa rin ang lagay. kotse natin ang binababoy nila e. dalhin mo na lang sa zeibart reasonable naman undercoat dun e, makapal pa. nag pa free tint ka? silipin mo mg mabuti rear windows mo.
- Feb 2011
- 35
June 12th, 2011 12:19 PM #309
June 12th, 2011 07:54 PM #310
