Page 12 of 56 FirstFirst ... 2891011121314151622 ... LastLast
Results 111 to 120 of 559
    Dec 2010
    #111
    For all Innova owners better start checking our tanks....mahirap na baka sa huli ang pagsisisi....
    Nov 2007
    #112
    hayy yung sakin tumagas na naman. Yung una na remedyuhan namin sa talyer, after 2 weeks tumagas na naman. Ngayon ko lang nabasa itong thread na ito meron pala talagang ganitong problema. Try ko muna maghanap nang 2nd hand na gas tank na walang sign of warping, then bili ako nang charcoal canister and new filler cup. Meron na bang nakabili nang charcoal canister sa banawe? sana me makita ako mas mura. Kung wala sa casa talaga.
    #113
    a few years ago, we put E-10 gasoline in our car and didn't use it for some time. a few weeks later, we tried starting it, but it refused to. finally, after looking at everything else, we found out that the fuel inside the tube and tank had solidified! we replaced the victimized parts.
    i am thinking now, that, is it possible the innovas being mentioned in this gas tank deformation mystery, are a victim of their breather tubes being clogged by alcohol-gasoline fuel mixture? has anyone examined the breather tubes of these tanks?
    btw, we had since sold this car...
    Nov 2007
    #114
    hindi kaya sa vacuum valve ang problema? i got this from toyota otis website:
    Fuel Tank Cap
    What is a fuel tank cap?
    It is a cap for the fuel tank.
    Importance of inspecting the fuel tank cap
    If the gasket is damaged, gas evaporates into the air.
    If the vacuum valve malfunctions, air cannot be drawn into the tank to replace the fuel used. Then, a partial vacuum occurs in the tank causing an indentation
    Evaporated gas
    In the fuel tank, some fuel vaporizes, containing a large volume of poisonous HCs (Hydrocarbons).
    Gasket
    Vacuum valve
    #115
    update lang sa innova namin. i-cover na daw ng casa under warranty sabi ng SA palit tank (daw) and cap kahit almost 4 years old na yun car. di daw sila aware na may defect ang tank ng innova e bakit pati yun cap papalitan nila? guilty haha. kaya yun may mga out of warranty na sa inyo try nyo na din muna sa casa sayang e
    Dec 2010
    #116
    Quote Originally Posted by jaymd View Post
    sir saan casa mo dinala?
    yung innova G (2005) namin, nagpalit na kami last May/June under insurance.
    Sabi ng talyer, baka daw may tumama. Today, pagkagising namin, may amoy na naman na gas. Ayun, butas ulit same area.
    May recall na ba si Toyota tungkol dito?
    Jan 2009
    #117
    Quote Originally Posted by Mile2 View Post
    Mahirap mapansin kung may sign na, pero kung palagi mong nasisilip ang ilalim maari mong makita agad. Sa umpisa maliit na dent lang sa malapit sa front gas tank strap support and then palaki na ng palaki at palapad ng palapad ang dent and then eventually you will hear metal popping sound sa ilalim after na pumarada ka at patay makina for about 10-15 mins. Yung popping sound sa gas tank floor ay sign ng pressure relief after the engine is off.
    katakot naman...
    parang hindi ko pa nasisilip ito mula nung inilabas (Dec 8, 2008) ko sa Casa innova ko... masilip nga tonight. huwag naman sana. lahat po ba ng VVt-i victim nito?
    so far wala pa akong na-experienced sa ride ko na tagas/amoy ng gasolina.
    Thanks
    -dongb
    #118
    our 2005 vvti innova, with 28,000km doesnt have the gas tank problem. laging full tank yung innova namin kahit hindi namin gamit.
    Jun 2010
    #119
    Na-gawa na Innova namin thru casa kahit out of warranty. I'll post the story later. Don't pay out of pocket.
    Aug 2006
    #120
    Kindly post your story.
    Ako 2 months ko pinaglaban yung 2nd gas tank ko sa casa..
Toyota Innova Gas Tank woes
