Results 11 to 20 of 37
October 24th, 2008 12:49 PM #11
to red orange:
thanks for the sound advice. you seem to be really knowledgeable on 4x4s.
jcc
October 24th, 2008 01:02 PM #12
Just something I learned when I got into off roading.
You don't want to buy a truck that was done by someone else unless you are sure of their work. You want to do the work yourself so when you breakdown off roading you can fix what ever breaks. Better to buy stock and wrench it yourself and learn, than to pay someone else to do it for you and have it break in the middle of no where and not know how to fix it. If you will be off roading things will always break because you puch the vehicle to it's limits. If it ain't breakin', you ain't tryin'. Remember 4x4=$x$.
Edit:
You mentioned a vibration on the SR5 on higher speeds. The vehicle suspension(leaf spring) needs to be shimmed to put the drive shaft in the proper angle otherwise it will have that vibration at certain speeds.Last edited by redorange; October 24th, 2008 at 01:09 PM.
October 24th, 2008 01:18 PM #13
"If it ain't breakin', you ain't tryin'. Remember 4x4=$x$"
hahaha. like i said, offroading is not really my main thing. i'm too much light on the pedal. could never make my vehicle scream.
just want a go anywhere vehicle with at least a "character" or "looks".
not planning on rock crawling, just a little bit of mud crawling when i have to go to my fish pond.
again, tnx. you have been very helpful.
ps. if you want to ask something about legal matters, i'd be happy to reciprocate.
jcc
October 24th, 2008 01:31 PM #14
October 24th, 2008 01:44 PM #15
i know that sir
like you in the tsikot community, i regularly give free legal advice online (in sulit.com.ph) whenever i'm not busy. i'm known there as legalcounselonline.
information, in my opinion, should be free. it's the service that is not. hahaha
dredd007.blogspot.com
jcc
October 25th, 2008 12:52 PM #16
Hi roadwarrior,
I'll insert my replies below:
if i replace the existing tires (36x12.5x15) with 31s, would the rig still look good? i have this fear that changing the tires to smaller sizes would make the rig look like it is on stilts.
the upgrades that i saw were the
1. tires (inteco ss) but half life already
2. rims (american racing)
3. shocks (sabi emu but not sure)
4. snorkel
my observation when i test drove the vehicle is that from the first gear to the third, parang normal lang. but starting on the fourth, this gets tricky as i can't seem to accelerate it faster than 60kph.
possible explanation (correct me if i'm misinformed)
1. i have a light foot, can't abuse the vehicle too much, resulting in lower rpm
2. the speedometer shows 60 but in reality it is faster than that because the speedometer is not accurate as it was reading based on smaller diametered wheels
3. the rig needs regearing para maging low speed
Time your shifts properly so that you can maximize your torque per gear.
A light foot really isn't much of a factor since if you are not applying enough throttle, the vehicle would just plain stall.
The speedometer is off since you are already running big tires, I'm just not sure by how much.
Re-gearing is a band aid solution as you will loose some speed later on due to the different gear ratio. Go turbo.
the suspension was also not bad but there are vibrations upon reaching the higher speed.
i am also not a first time diesel driver. i've had a second generation strada (2000 model) which served me very well (i sold it after 160thousand kms and after 8 years of honest to goodness usage). i remember that old clunker was beautiful and speedy also (150 kph topspeed), that's why i was expecting the sr5 to at least approximate its performance less allowance for the huge tires. but sadly, not even close.
Hope this helps.
Best regards.
October 25th, 2008 02:29 PM #17
Im not sure the price back home, but a 675k 8 years old truck seem's like bit high. The only expensive parts for a lifted trucks are the fat tires and rims. Use RANCHO on shocks they are superior when it comes to lifted truck.
If you put over sized tires on it however the speedometer will need adjustment.
If the speedometer was adjusted to over sized tires and you use stock, you will be going much slower then you think.
So find out what has been done before buying and just get the parts to match the changes (tires that match the calibration on the speedometer.
October 25th, 2008 08:48 PM #18
to hardcharge and v6dreamer.
tnx for the replies. it's like i'm learning 4x4 101. with the opinions posted so far, the safer route it seems is to just find a bone stock vehicle and modify it slightly but not much. meaning at least slightly larger tires which the wheel wells could accomodate without modification.
so many decisions.
i like the bullet proof characteristics and high resale value of the hiluxes (but the sr5s seem to be underpowered?, the new one, too expensive for just a workhorse)
but i also prefer the ride and comfort provided by the stradas (whether 2nd gen or rise body). (but there seems to be issues as far as steering is concerned with the new strada?)
as far as torque and macho stance, the ranger seem to fit the bill but i'm not familiar with the suspension (is it bone-jarring?)(does it really deserve the low resale value? why?)
jcc
October 25th, 2008 09:06 PM #19
Farm duties? how about this sir..P665,000 thousand
http://tsikot.yehey.com/classifieds/...ct/54960/cat/6
October 26th, 2008 06:37 AM #20
Tesla Philippines
