Results 1 to 10 of 10
- Jul 2008
- 398
May 12th, 2013 08:06 AM #1My mother has a 2012 fortuner. She is always complaining about the bumpy ride. I am getting itch to change the suspension parts. Any ideas where to start from?
p.s. This fortuner is said to have an improved suspension over previous models but still lags behind a 2000 pajero in its suspension department
May 12th, 2013 08:20 AM #2
Old Man Emu and Ironman both make a suspension kit for the fortuner. Buy the spring and shock combo as they are designed to work as a system.
May 12th, 2013 11:19 AM #3
Yung ironman suspension yata hindi progressive yung spring rate baka matagtag.
May 12th, 2013 01:44 PM #4
Tein, though providing a slight drop, is said to give a much better ride than stock springs. Some are saying in the Fort's case, that the tagtag is due to the springs since they were designed for load capacity.
May 12th, 2013 09:12 PM #6
May 13th, 2013 03:39 AM #7
O-sulee takes some of the edge off road bumps, providing some cushion whereas you'd be jarred more without it. But getting better shocks/springs would be the more comfortable solution.
Posted from my iPhone
May 13th, 2013 06:29 AM #8
May 13th, 2013 10:46 AM #9
That is also my problem before, I tried TRD with O-sulle but it has an issue with bottom up if your tire is on 20", but if you use stock tires TRD is good.
So I have to find another solution , and use Rancho shocks, RX900 XL, now the suspension in working good and also Rancho is adjustable.
Tesla Philippines
