Results 1 to 4 of 4
- Apr 2009
- 272
September 16th, 2014 06:27 AM #1Hi Guys, Im not familiar with the cost of spare parts, can you give me the estimated price of the following parts? This are for repair of Corolla GLI 97
> Front shock absorber
> GV Joint bearing
> Front wheel bearing
> Clutch lining
> Release bearing
> Timing Belt
> Tensioner bearing
> Oil seal
> Rear stabilizer
> Valve Cover gasket
> Fan belt
> Transmission support
> Fan belt tensioner bearing
> Tint installation (medium black)
September 16th, 2014 09:10 AM #2
Give Toyorama (Banawe) a call. You can google their number. Other Toyota part stores are Gant (Pasay), Celica (Araneta Ave) and Aerodynamic (Masangkay).
For parts like the valve cover gasket, transmission support, oils seals and timing belt go for original Toyota. For suspension parts, KYB or Tokiko shocks are good. For your clutch, Aisin. For the tensioner bearing, Koyo bearings (Same as Original). As for price, i can't tell but i'd budget around 20K. The clutch parts and shock absorbers alone will reach around 10K already most likely.
Given the repairs to be done, you may want to change your water pump already as well.
September 16th, 2014 02:16 PM #3
September 17th, 2014 09:09 AM #4
^Replacement (GMB?) is cheaper than OEM (Mga 1K more or less) and should do the job.
Tesla Philippines
