Results 1 to 8 of 8
- Aug 2011
- 336
January 26th, 2012 12:52 PM #1sirs! Good day po. Tatanong lang po sana ako kung saan nakakabili ng 4age silvertop engine? Plan ko kasing magpalit sa ae92 ko. Saan po at magkano ang bentahan ng 4age engine ngayon? Thanks po!
January 26th, 2012 01:20 PM #3
Wow, 40T na rin ah.
Things to look at when you're engine shopping:
- wiring harnesses (properly cut and taped and/or with it's proper clips)
- axles
- transmission
- ECU
- engine mounting condition
- bolts (complete and not deformed)
- sensors
You'll also need to rewire for a different fuel pump as you car is coming from a carb and will become EFI. Be prepared to do some part changes as well (bearings, gaskets, water pump, compression test, etc) since it can be done easily before the engine is mounted on.
Best to find a shop who'll do the swap first then you look for the engine and it's assorted parts. Don't go with the cheapest deal but look for a shop that is recommended with good feedback. Normally you'd end up spending more if you go for a cheap swap.Last edited by vinj; January 26th, 2012 at 01:22 PM.
- Aug 2011
- 336
January 26th, 2012 01:21 PM #4sa 40t po ba na yon excellent condition pa yung makina? Tiyaka saan po ako pwede maghanap ng silvertop? At kumpleto pa po ba makina non? Ecu, tranny, etc? Thanks po, pasensiya na po madaming tanong..
January 26th, 2012 01:37 PM #5
- Aug 2011
- 336
January 26th, 2012 01:57 PM #6ah ok po, may nabasa ako na yung tranny ng 4af ay pwedeng isalpak sa 4age.. Sana nga ppwede siya para bawas gastos.. Salamat sa reply sir, sana makahanap ako ng naka condition na makina.. Sa mga may alam kung san ako mkakakuha ng 4age, paki lagay nlang po dito.. Salamat sa makakapagbigay.. C:
January 26th, 2012 02:44 PM #7
ya kaya presyo ng engine pinost ko coz pwede mo gamitin yung orig tranny
January 27th, 2012 09:41 AM #8
Kaya i really loved those front cuts before which came with all the JDM goodies.
Tesla Philippines
