Results 1 to 9 of 9
- Mar 2013
- 2
March 13th, 2013 11:39 PM #1Good Day po sa inyo.
Meron po akong Toyota Corolla Big Body po ako. May napansin po akong oil leak everytime nagpapark po ako sa bandang right po ilalim ng hood.
Pahelp naman po sa mga tanong ko?
1. Ano po kaya ito?
2. May recommend ba kau na trusted shop na magaling magayos nito? Taga- QC po ako.
Thank you for the time.
- May 2004
- 903
March 14th, 2013 10:49 AM #2pa lifter mo muna then tignan kung saan galing.. from there malalaman kung ano dapat palitan...
March 14th, 2013 12:22 PM #3
- Jul 2011
- 1,711
March 14th, 2013 02:02 PM #4Sir agapan mo yan, kasi langis yan mamya maging cause pa ng pagkasira ng engine mo yan, mas malaki ang gastos.
March 14th, 2013 02:08 PM #6
Have your engine cleaned (washed) on top and below as well. When everything is nice and clean, you can now exactly pinpoint on where that oil leak comes from.
- 53,883
March 15th, 2013 06:38 PM #7"oil leaks" (especially with in-experienced car owners) can be from:
1. the engine;
2. the power steering;
3. the radiator;
4. the aircon condensate..
5. the family dog!
in my experience, searching for the source of the oil leak can be very frustrating.. even with a good engine wash.. good luck.Last edited by dr. d; March 15th, 2013 at 06:42 PM.
BANNED BANNED BANNED
- Jun 2011
- 125
March 15th, 2013 07:48 PM #8
- Jun 2013
- 5
June 14th, 2013 01:07 PM #9
Mas maganda, ipa engine wash mo muna at ipalinis mong maigi yung ilalim ng makina mo, then gamitin mo muna for a few days considering you always check your engine oil level. Then ipa lifter mo ulit at ipa sipat mo na sa mekaniko kung saan nanggagaling yung tagas. Madaming pwedeng pagmulan ng tagas at usually sa left side ng engine, kung saan nandun yung timing belt mo ( left side pag nakaharap ka sa makina mo) kasi nandun lahat ng oil seals at maganda pag pinabaklas mo, papalitan mo na lahat ng oil seals/o-rings, tsaka sa oil pump seal/gasket na common source din ng tagas. Pwede ring sa oil sump gasket lang or mismo sa drain plug. pwede rin sa valve cover gasket mo kasi pag malutong na, nalabas na rin ang langis lalo na pag barado rin PCV mo. Kung rear crank seal naman, medyo labor extensive kasi kailangan baklasin transmission mo pero sa transmission side naman ng engine mo dapat natagas. Unti unti mauubos din yan, hope this helps.
Tesla Philippines
