Results 1 to 10 of 10
- Apr 2009
- 272
December 10th, 2014 01:02 PM #1everytime mag bbreak ako may squeaking sound, ano usually cause nito? could it be dangerous? Whats the best thing to do? and if ever pa check sa shop how much ang labor?
December 11th, 2014 11:23 AM #2
most probably, worn out brake pads.
cost would depend on what your car is.
- Oct 2014
- 339
December 11th, 2014 11:30 AM #3
- Oct 2009
- 2,271
December 11th, 2014 05:38 PM #4san ba ung maingay harap or likod ..brand ng sasakyan .at tear model po
paki lagay..
minsan sobrang dumi na or bakal sa bakal na ,(upod na ung pad or brake shoe,)
kung makapal pa ang pad,or shoe linisin mo nalang ako sand paper gamit ko at scotch brite
- Dec 2014
- 5
December 26th, 2014 11:42 AM #5Tama sila lahat. Kailangan nang palitan ang front or rear brake pads.
- 53,883
December 26th, 2014 11:50 AM #6squeeking sound? baka springs lang.. or need to lubricate something.
squealing sound? it might be the built-in warning device, telling you that your pads are worn out and need replacement. pad wear is easy to detect.. nasisilip yan sa harap, nguni at kailangan mong tanggalin ang drum kapag sa likod.. basic mechanics.. easy to do.
but i agree.. you have to have it seen by a (brake) mechanic..
- Apr 2009
- 272
January 8th, 2015 04:14 PM #7front right side po ang maingay. Ok lang po ba maglagay ng lubricant? ano magandang lubricant po ang pwede ilagay? baka may temporary solution. Car is Toyota Corolla 97 gli
January 8th, 2015 04:21 PM #8
if the problem is at the brake pads, lubricating them will eliminate the friction that you need to brake.
kung baga, pag kapit ng brake pads, madulas, so hindi kakapit.
much better if you can check/replace your pads or have it diagnosed properly.
squeaking lang naman yan eh.... tiisin mo na lang muna until you can have it repaired/diagnosed properly.
- Jan 2016
- 25
February 4th, 2016 06:06 AM #9No-no yan pre. If you can't do it, let someone else(a trusted mechanic). Maghanda ka ng 3-5k. Yun labor nsa 400 lng pero sana ayusin ang adjustments at hindi basta i-rreplace lang ang break pads at break shoe. If you are not sure kung napalitan n ang mga yan e might as well, palitan mo n lng ngaun. Don't let it run like that kc ang damage baka mas lumala pati buhay mo at passengers mo. Careful.
- 53,883
February 4th, 2016 11:11 PM #10
Tesla Philippines
