Results 1 to 10 of 14
    Jan 2003
    Unless your engine is already hot, no, it's not normal. Lalo na't bagong-bago pa sasakyan mo.
    May 2009
    Quote Originally Posted by Yoda View Post
    Mainit na nga siya bago pa man is half-start. Galing sa dealer. So nothing to worry ako? Pero kasi yung Honda ko hindi naman ganoon. Bakit itong VIOS lang?
    Jan 2003
    I think I should rephrase.
    Does it happen ALL the time? Even from a cold start?
    Oct 2008
    sir ano yun naka direkta na po?
    May 2009
    Not all the time. Kapag 'hot start' lang so far sa Vios. Pero sa Honda City hot start or cold start. never nangyari.
    Jan 2004
    I think this is normal. Had the same situation with my Vios.
    once you start your engine from cold start hindi pa iikot ang auxiliary/engine fan pero pag on mo ng a/c automatic din mag on ang auxiliary fan. i noticed this sa sentra, kia rio and kia carens ko.
    iikot lang ang auxiliary fan once your engine is running and had reach the operating temperature.
    so i think hindi normal yan.
    Sep 2004
    On my 97 Accord, pag higher than normal ang temperature ng makina (usually dahil kulang na sa coolant), umaandar na ang aux fan kahit nasa ON position pa lang ang susi. This also happens when I try to restart the car a few minutes after shutting the engine off. Umaandar pa rin ang aux fan.
    I used to think it was weird, since tinanggal ko na ang susi at patay ang makina.
    So I guess normal lang yan. Baka kasi may temp sensor din yung 2009 Vios.
Question sa VIOS engine fan...
