Results 1 to 8 of 8
- Jul 2010
- 166
August 12th, 2014 03:00 PM #1magtatanong lang po kung pareho lang ba ang pag crimp ng hose steering at sa hose ng aircon? kasi po may leak na steering hose ko, plano ko iDIY, ang gusto ko po sana bibili na lang ako ng steering hose tapos ipacrimp ko sa mga gumagawa ng aircon. gusto ko sana malaman kung pareho lang?
August 12th, 2014 03:04 PM #2
Parehas lang po. Nasa barbs yan ng fitting at ang ferrule parehas din. Most aircon hoses are designed with 500 psig bursting capability. The power steering pump relief valve opens about 150 psig
Posted through phlpost.gov.ph
August 12th, 2014 05:11 PM #3
Pasingit rin guys... We have a leaking power steering hose that needs to be replaced. Most shops still need to bring it somewhere to get it fabricated. May marrecommend ba kayong shops na pwede na kaya na gawin ung labor + fabrication at the same place? Thanks!
- Dec 2011
- 37
August 12th, 2014 10:45 PM #4*devond
Unless you're an experienced mechanic, I think its best if you let a professional do the hose replacement. AFAIK the pressure of the fluid that goes around inside the power steering is high. Besides its messy.
*kotiko
Your location? Fyi there is a shop that do both. Its along amang rodriguez, santolan pasig (almost) near south supermarket. Sorry i cant remember the name of the shop. I had my power hose replaced. it cost me 1500 (hose, labor and fluid). Btw the fluid i purchased myself
Cheers!
August 12th, 2014 11:45 PM #5
- Dec 2011
- 37
August 13th, 2014 02:26 PM #6It's on the left side. Nearest landmark is KIA AUTO SHOP. You would probably see a big sign that says "POWER STEERING HOSE"....something like that. Sorry again, I happen to passed by that area to pick up my kids from school and I forgot to check.
AFAIK the shop only specializes on hoses.
When you get there, tell them your problem, and they will inspect and quote you the cost. Buy your own power steering fluid.
Cheers!
- Jul 2010
- 166
September 9th, 2014 09:20 PM #8naayos na po yung powersteering hose ko, nasa 700 po nagastos, maraming salamat po sa mga reply.
Tesla Philippines
