Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Sep 2010
    mga boss,
    pano ba process ng door panel replacement sa mga Toyota casa?
    yung panel ba is me pintura na galing planta o sa casa lang pinipinturahan?
    sabi nung SA na naghandle nung repair sa oto ko ay
    pinalitan "daw" yung 2nd row door panel ng oto.
    pero me part na walang topcoat as in litaw yung metal.
    di ba fully painted na yun galing planta bago ikabit sa unit?
    eh nakalimutan na hingin yung pinalitang panel di tuloy
    nacheck baka pinukpok lang sa casa yung damage.
    wala kasi ko sa pinas kaya misis ko nagaasikaso.
    ipinababalik sa lunes.
    tia.
    May 2005
    Panels come with a very thin coat of paint (this is the primer or first coat) to protect it from immediate rust.
    Dealers or repair shop will spray the layers of body color paint and lastly the clear coat.
    You can easily tell if the shop simply applied body filler/putty or masilya, by using a soft refrigerator magnet. Place the magnet on the formerly damaged areas. The magnet must stick with a very strong bond otherwise its full of putty or body filler.
    Check the inner side of the door panel. Feel the areas near the rubber gasket around the door. Is it smooth or does it feel like a fine sandpaper? Is it the same color/shade as the rest of the outer panel ? Is there a different color underneath the rubber gasket ?
    Not all shops will replace it with factory freshly stamped panel (esp. if its an older and outdated model). Most of the time they will source the panel from other cars that have been parted out due to being total wreck, chop-chop, etc...
    PS: Toyota Phil still stamps out Revo panels (hatch door, etc...).
    Jan 2009
    mine has been replaced (2 doors) with black color eto daw talaga ang baseline color nila to be uniform then pinturahan nila ng body color ng car na required
    The CASA will be the one to paint the panel.
    In the case of our Grandia GL, nung nasabitan siya on the left side (no sliding door side), the CASA first wanted to latero + masilya but we were able to push for the whole side panel to be changed (laki nun, the part from the b-pillar all the way to the back).
    Sep 2010
    salamat mga boss.
    palpak pagkakapintura ng toyota plaridel.
    back job tong ginawa sa oto ko. tsk tsk
    ibabalik ni misis monday.
    Rare ako nakakita ng CASA na magalung sa paintworks really.
    May 2005
    Most of these supposed dealers simply outsource the bodywork and paintwork to outside shops (or third parties).
    ^vinj, I'm impressed that Toyota dealer managed to replace the entire panel of your Grandia. Most of the workmanship in these kind of shops (places that need to a fast turnover to make a buck) do more damage than repair due to their incompetence and poor attitude.
    Actually you basically remove off the entire panel (there's a seam that separates it at the driver door, roof gutter and tailgate. The paint job sucked since they did not get the pearl white correctly, i had a backjob on the window as there was a small leak when pressure wash the car and now i see a little corrosion on a part of the weld near the wheel well. I'll have it repaired by an outside job instead since we have to repaint the rear bumper too (naatrasan ng flower box yung driver ).
    Still better than the originally proposed latero work on the dent though. It took prodding on the side of my Tita who had contacts with the insurance company too.
    Aug 2006
    Panel replacement comes in black coating, then casa will paint it according to your body color.
    Karamihan ng casa palpak ang color matching lalo kung metallic, base from my exprience may case ako na umabot sa 7 repainting dahil di nila makuha yung metallic density, yung metalic kasi may certain angle yan na pag di match ang metalic density nag-iiba ang kulay kaya minsan dinadaya yan ng pintor at over-spray nila ng konti yung adjacent panels para mag blend. Painters called it "sapyaw"
    One of the best casa pintor na naexperince ko is Toyota Makati, sabi ng SA doon mga seasoned painter daw nila yon na galing pa sa old Toyota Bel-Air (Buendia) na wala na ngayon.
    Nov 2013
    Quote Originally Posted by Mile2 View Post
    Up ko lang ito. Just had a rear bumper repainted. Off parin ang shade after 3 attempts ng casa. Sabi saken they used the correct paint code naman, now I'm still unhappy about the results and wondering why can't they get the color matched perfectly. I do understand that bumpers are a little bit darker than the body, but mine is way darker than the rest of the car at certain angles.
    How do I instruct the casa to get the metallic density correct?
Panel replacement sa CASA
