Results 191 to 198 of 198
March 25th, 2012 01:57 PM #191
March 25th, 2012 02:39 PM #192
- Sep 2008
- 115
June 5th, 2012 03:10 PM #193kamusta na mga innova nyo?may black smoke pa rin ba?hirap pala D4D ng TOYOTA.mukhang di sila okay sa diesel.to think na eto ang de facto na reliable na car for the pinoys.yun pala may problema din.to think na engineers from toyota plant na pumunta ganun pa rin. so far mukhang pinaka reliable pa rin ang HONDA.very few complaints nababasa ko sa forum and okay daw after sales nila.i guess okay na rin na medyo mahal ang honda kung hindi naman sasakit ulo mo
June 5th, 2012 06:31 PM #194
June 5th, 2012 06:38 PM #195
*7138 is correct, how can you compare the D4D of Toyotas to Hondas in general when they have no diesel engines to begin with? Besides, yung pag-emit ng black smoke really depends on how you use the car and where you fuel it up. Dirty diesels can somehow tamper your engine's performance and may contribute to the black smoke that other Innovas blow out.
Honda's aren't perfect. I have one, believe me.. it costs a testicle to repair a defect. My engine support broke down on me when I was still ~50k kms, same goes for the tensioner. And now, the handbrake seems to start failing too. The repair cost for the first said items are expensive if you'd compare it to Toyota.
Kung lumabas lang yung 10th gen Altis back 2007, I might not have gotten the Civic. Baka dun nalang ako sa Altis.
June 5th, 2012 06:41 PM #196
is that an FD?
exactly whats happening to my boss' FD. first was the engine support, then tensioner, then driver side window, then hand brake lever is about to give way na.
BTT: maintenance is also a big factor. a dirty air filter will make a bnew diesel fed engine belch black smoke.
June 5th, 2012 06:45 PM #197
Yes bro.-, 2007 Civic FD
So far pinagttyagaan ko muna yung handbrake lever, pinipindot ko nalang yung ilalim para hindi maipit yung button niya.
As for the tensioner & engine support, it costed around 22k to repair it. Sana naman wala na masira pa. All four power windows are still working properly as of this date.
BTT:
Although I've seen Fortuners & Innovas emit black smoke, they're the ones who aren't kept well. Halata niyo naman by its aesthetic appearance pa lang. Tail lights are discolored already, maraming dings & dents..
So you can somehow assume na if your unit undergoes proper service intervals there's nothing you should worry about.
May 16th, 2013 03:03 PM #198
Sorry to bring up an old thread.
Update on my 2010 Innova J diesel, still no problems except for a gash sa upholstery ng driver's seat. Ano na balita sa mga Innova niyo? Did you get these smoke and choke problems fixed?
Tesla Philippines
