Results 1 to 3 of 3
    Jun 2013
    Hi guys. hingi lang sana ako ng tulong sa inyo... i have a 92 corolla smallbody. ang problem po eh pag mainit na yung makina, nakaaircon, matagal ng umaandar...at nagstop ka sa stop light or humps or nakafull stop ka.. eh biglang patay yung makina.. pero pag start mo ulit, one click lang start na agad ulit... nagpalit na ko ng fuel pump brand new, nagoverhaul na rin ng carb, pero ganun pa rin... suspect ko na lang eh ignitin coil and high tension wires or distributor.. please help po.. thanks guys
    Aug 2004
    Check that it's not flooding... see if the spark plugs look wet. Also check your vacuum lines.
    Overheating ignition coils can go out even during steady cruising... if it happens when you come to a stop or when you're stopped, it might be a vacuum or idle issue.
    Jun 2013
    thanks sir.. ill take a look into it.. :-)
Dead engine pag mainit na
