Results 41 to 49 of 49
- 53,883
March 14th, 2015 12:37 PM #41- - - - - - - - - - - - - - - - - - - - - -
humans come in one basic design, and with only four variants.. adult male, adult female, child male, and child female.
the rest are... political variations.
and after hundreds of years of scientific study, there has been no change in model design. not even a little bit!
and yet we still get things wrong!
heh heh.Last edited by dr. d; March 14th, 2015 at 12:42 PM.
- Jul 2008
- 398
September 17th, 2015 07:22 AM #42Quick fix for overheating old engines
Change radiator
Change radiator hose
Change thermostat
Change coolant temp sensor
Done this to 3 cars. All running perfect ever since. Diy lang, watch YouTube.
- Jan 2016
- 25
February 4th, 2016 06:01 AM #43Let a trusted mechanic check the radiator and the air-conditioning system. There must be a leak. Are you sure, you check the water level? Don't rev the car too much when you start in the morning. Our hot weather is already convincing for the car to be warmed-up enough like 10 seconds. Takbo na pero syempre not that fast nmn. Ingat. Hassle yan pag tumirik so wag mo ng patagalin pre.
February 6th, 2016 08:50 AM #44
pwede ka gumawa ng mas murang version doc. hindi naman araw araw na ginagamit kaya impractical sa diyer yung mga prof kit. andami sa youtube. tignan mo ke schrodinger's box o kay ratchetsandwrenches. pero kung gusto mo talaga yung mamahalin na kit e may kakilala ako tiga pasay (hindi sa likod ha
ang kelangan e either tire valve or quick coupling, radiator cap, air compressor o kahit yung manual hand pump. atsaka pressure gage para imonitor yung applied pressure sa radiator.
if in doubt ako sa radiator cap e agad ko na lang na pinapalitan. no need to test na imo bukod sa manual testing (by hand) nung springs. mura lang naman.
February 6th, 2016 05:34 PM #45
If you don't have access to a pressure tester, use a bright light color dye and add it inside the radiator. When it should leak, it will leave a trace
- Jan 2016
- 25
June 16th, 2016 11:27 PM #46
- 53,883
- Aug 2013
- 7
June 26th, 2016 01:01 AM #48same problem din po, when i was on my way going up to baguio every week pag lampas sa may lions head, nag uumpisang tumaas temp ng engine ko to more than one half ng gauge. bago naman ang thermo stat, radiator ok din, ok naman fan nya, pati head gasket. sa may paakyat lang talaga nangyayari to. pero sa patag ok lang. ive been using 5 cars pero ngayon lang to nangyayari sakin. kung mag 2 row radiator kaya ako will it solve may problem?
- 53,883
June 26th, 2016 10:33 AM #49
