Results 1,141 to 1,150 of 2049
- Dec 2014
- 55
March 9th, 2015 04:09 PM #1141Nga kaibigan, 3 beses na ako nasisiraan ng fuse para sa Phone Car charger. Ano po ba ang maganda na gawin? Nagtry na po ako ng brand na elevo, cdr-king kaso lagi nauuwi sa nasisira.
- 53,883
March 9th, 2015 05:53 PM #1142strange...
you can check the fuse used. it might be "sub-standard", that is, it may have a rating lower than what is listed down.
check also if the fuse box heats up..
if that fails, you might have to open 'er up..
strange...
- Dec 2014
- 55
March 9th, 2015 07:29 PM #1143In those instances that I had to replace the fuse, I sought assistance from casa. Should I put in a fuse with higher volts? Wouldnt that make things worse? By the way, thank you for the response, mate!
- 53,883
March 9th, 2015 07:44 PM #1144
- May 2013
- 140
March 10th, 2015 05:05 AM #1145Sir ano sabi sa casa? Ni-test ba nila? Ako 2 times naputukan ng fuse. Dun sa pangatlo, iniwasan ko yun mga more than 1A rated at two port charger and gumana sya. Kaya ayun, nung bumili ko portable compressor, takot ako iplug dun. Tingin ko low ratings na fuse nakalagay sa mga naunang nasira. Sa next PMS ko, papatest ko sa kanila yun compressor kung gagana pati mga unang charger na binili ko
- 53,883
March 10th, 2015 10:11 AM #1146
March 10th, 2015 11:44 AM #1147
Normally, Cig lighter ports can accommodate only up to 10A max. What is the label rating on the port's cap (cover)? Mine says "12V 10A max". I am assuming it's pretty standard across all makes.
- Dec 2014
- 55
March 10th, 2015 06:22 PM #1148
- Dec 2014
- 55
March 10th, 2015 06:26 PM #1149
- 53,883
March 10th, 2015 06:39 PM #1150can't be.. 2.1 milliamperes is too small for anything except standby mode.
at any rate, if the fuse is not sub-spec, perhaps it is time to explore "poor wiring" as cause for fuse blow-out.. as in, something shorts when the charger port is used..
