Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Aug 2011
    Mga sir, paano po malalaman kung sobra o kulang ang gear oil level para sa 1990 toyota corolla 16valve engine???
    Gaano po kahalaga ang gear oil???
    Paano po malalaman kung sira na ang oil seal???
    Na rereplace po ba ito ng hindi ibaba ang transmission???
    KAYA PO PA BA MA HOME SERVICE LANG SA MEKANIKO???
    Mga magkano po kaya ang labor at materials???
    Sana po may mag share sa akin para matulungan po ako!!!! Salamat po in advance!!!
    If the car is sitting on level ground, remove the fill bolt for the gear oil and put your finger in the hole. You should be able to touch gear oil. If not, kulang yan.
    Or just drop by a gas station that has a service bay. They can check for you.
    Gear oil is easy to change. The seals for the transmission requires a pull down to be changed.
    Feb 2009
    Quote Originally Posted by ernz23 View Post
    there are three oil seals of your M/T. two output shaft seals and one input shaft seal. the input shaft seal is a might as well (MAW) operation when you have the clutch replaced while the transmission is still out and the input shaft seal and the engine rear main seal is readily accessible. the output shaft seals can be replaced while the transaxle is still on board and installed. it requires the halfshafts to be pulled out of the way. if the oil seals are okay and the transmission oil seals is not overserviced but the oil leaks from any of the three seals, check the transaxle breather at the top to make sure it is not clogged up
    Aug 2011
    thanks sir otep
    Aug 2011
    thanks sir jick.cejoco
    90's corolla transmission are bullet proof pag tunog grinder tranny mo sira
    Aug 2011
    EE100shiro: Sir ok nman tranny ko, kaso may konting tagas sa may oil seal hindi ko alam kung sobra or kulang ba ito ng gear oil kasi pinapalitan ko ng bago sa petron last November 30, 2011, Dati naman wala. Makaka apekto po ba ito sa transmission ko at performance? ok naman po ang shifting of gear ko swabe naman po. May tagas lng po pag umaandar ng konti.
    Kaya po kaya pa home service sa mekaniko pag pinaplitan ko ng oil-seal, ginamitan ko po ng jack last saturday at nasilip ko ung tagas. Mga magkano po kaya parts and labor pag sa labas ko pinagawa.
    Many thanks po sana may makatulong dahil basic lng po alam ko sa kotse!!!!
    2,000 pesos kung ibaba mo tranny mo palitan mo na rin ung oil seal na malaki malapit sa flywheel para isahan tanggal na lang
    oil seal ->flywheel ->clutch disk ->pressure plate
    one oil seal shaft (behind release bearing) and 2 oil seal (ung may panyo) left & right connected to your CV tire
    Aug 2011
    EE100shiro: Sir thank you sa pics, yan na po ba yung actual pag kinalas ung transmission ko? salamat po sa sa mga suggestions kasi hindi ako masyado maalam baka maloko ako pag pinagawa ko sa labas.
    Jun 2012
    Mga Sirs, i need help regarding my newly purchased corolla 1991 2e engine. It's equipped with battery which is 12 plates. Is this the appropriate battery for such car? what's the implication of using batteries not the specified one?
Gear oil level???  For 1990 toyota corolla manual transmission 16valve engine!!!
