Results 1 to 10 of 13
- Jan 2009
- 13
April 25th, 2010 05:52 AM #1just bought 2009 viosG M/T(2nd hand), 2400 (odometer reading), 1 week pa lang sakin ..minsan ayaw niya mag-start-start agad;(walang redondo; of course NAKA-APAK SA CLUTCH PEDAL!) even just right after shutting off the engine..Pero after trying several times ,eventually nag-start naman.. defective na kaya key(with transmitter)?
Or malfunctioning na kaya yung immobilizer system? May naka-experience na po ba nito dito?
Help pls, guys!!
TIA
April 25th, 2010 07:56 AM #3
Yeah suspicious sobra... Sobrang bago pa lang (2900km odo reading) binenta na agad... How much did you pay for it?
- Jan 2009
- 13
April 25th, 2010 10:38 AM #4naku di naman sana.. anyway ok naman amoy ng car, bago talaga, location niya is merville paranaque (sana di binaha dun)..stock ang alarm and stereo..kaya pakiramdam ko di naman ondoy victim..Under toyota warranty pa naman, pa-check ko na lang po cguro..
Up ko na lang din po..
More input po sana guys, pls help..
tnx..
- Sep 2009
- 368
April 25th, 2010 11:17 AM #5When you bought the car did you check the service records? You should do a background check first, like calling the Toyota CASA who has the car's service record or checking with the cars insurance company for 2009-2010 since they can confirm if the car was flooded. The Toyota Warranty Booklet of my 08 Vios says that Acts of God "is not covered" and will void the 3 year/100,000km warranty. It did flood pretty badly here in Paranaque (waist deep) in the wake of Ondoys wrath, but it depends if the previous owner drove the car through flood waters high enough to reach the electrical system; ECU, Starter Motor, Immobilizer/Keyless Entry Module, Airbag Sensors, ABS-Unit, Electronic Power Steering Unit, Eletronic Throttle Control and the Clutch cut-off switch, all electrical and could deteriorate over time. If the records are clean, check the under the carpet for traces dirt or water marks, since you've mention the car was clean it could've been detailed to remove the flood water odor and stains. Also look the bolts and screws in the interior if they look like they have been previously removed or showing any signs of rust. Hope you can have your vios fixed in a jiffy
I just hope it could be just a defective or loose Clutch cut-off switch since that is quickest and easiest problem to fix...
- Jun 2004
- 1,311
April 25th, 2010 11:19 AM #6kung may warranty pa naman sa toyota pa check mo na lang muna
on a side note bumaha sa slex area malapit sa merville nung ondoy, 2-3 ft high dun sa service road malapit sa merville
April 25th, 2010 03:23 PM #7
yes. have it checked at the casa first.
I bet the previous owner denied any flooding
- Feb 2010
- 16
April 27th, 2010 10:28 AM #8
--> try adjusting ung floor mat mo..para talagang sagad ung apak mo sa clutch.. kasi minsan kala mo sagad na ung apak pero di pala dahil nahaharangan nung mat.. o kaya make sure na talagang todo (as in todo ung apak mo hanggang dulo) ngyari din kasi skin yang sinasabi.. auto ko 2010 vios.. for the first 2 mos.. hirap na hirap din ako iistart ung auto.. as in same experience tayo na kala ko nga nuon defective.. i even reported it to toyota.. pero i realized na kailangan lang talaga apakan ng husto ung clutch.. dahil kung di.. hindi tlaga mags-start yan.. nakaka-frustrate pero once makuha mo na ung tamang timpla.. panalo yan!
April 27th, 2010 11:12 AM #9
wala redondo pero may naririnig ka bang click (tunog ng bendix drive) kung wala baka sa cut off relay ng alarm or immobilizer or sa ignition switch, pero alam ko vios wala immobilizer.
Take note yan ay isa sa mga symptoms ng mga na ondoy at na pepeng. Sana hiningan mo ng certificate of flood free from toyota sa seller. Kung casa maintained yan alam ko nagbibigay sila
April 28th, 2010 06:38 PM #10
Bro just a quick warning, binaha kami sa merville / moonwalk area nung ondoy. Depende lang kung saang street siya sa merville siguro. Not saying binaha or hindi, but it's a possibility.
Tesla Philippines
