Results 71 to 80 of 111
June 26th, 2015 04:05 PM #71
problema talaga sa smartphone yang madaling ma-drain kaya nga balik na ako sa bar phone. isang charge pitong araw na
BANNED BANNED BANNED
- Jan 2015
- 4,580
June 26th, 2015 05:51 PM #72
July 30th, 2015 09:39 PM #73
July 31st, 2015 09:44 AM #74
Depends on your phone's internal memory, or if your phone has the option to transfer app data to SD Card. Usually kasi half (minsan more than pa) ng internal memory nakain ng OS, yung natira na lang is pang apps. And even if you have the option to transfer apps to SD card, mag ooccupy pa din siya ng space sa internal memory.
- Mar 2014
- 901
July 31st, 2015 10:14 PM #75Depende nga sa phone's internal memory. Kapag mababa, palagi talagang mag-prompt ang "insufficient space". Some apps bagamat transferable sa SD card, still uses a certain amount in phone's internal memory. When and upon downloading, kailangan din ng malaking amount of space sa internal memory to sink-in or install the app you're downloading. You must take a look in its specs about the RAM and ROM of a smartphone. Mas maganda kung ang RAM mo ay 1GB at ang ROM ay 4GB or 8GB(mas better).
Sent from my UP+ using Tapatalk
August 1st, 2015 02:41 PM #76
August 1st, 2015 07:01 PM #77
- Jun 2015
- 27
August 1st, 2015 09:11 PM #78Ask ko lang po ung iphone ko kapag nasa bahay walang signal pero kapag nasa labas ako meron pero may time na hindi din nagsesend yung messages. Pinacheck ko ung antenna oks naman daw baka baseband ang problema? Magkano po kaya parepair nun?
August 1st, 2015 09:26 PM #79
- Jun 2015
- 27
August 1st, 2015 09:36 PM #80Globe. Hassle lang talaga lalo na postpaid tapos nakalock in pa ko. May way kaya to para maboost ung signal?
Tesla Philippines
