Results 1 to 10 of 13
March 8th, 2009 11:53 PM #1
Thank you to Larshell for lending me his stock springs and shocks. For reference purposes. Here we go:
Rear shock: Suzuki Tokico 1700-81A0 YF3 (gas type)
Extended:
Compressed:
March 9th, 2009 12:00 AM #2
Front shock: KaYaBa 1600-81-12 YF26 (fluid type)
Compressed:
Extended:
March 9th, 2009 12:06 AM #3
Front coil spring:
March 9th, 2009 12:08 AM #4
Rear coil spring:
March 9th, 2009 12:08 AM #5
Rear coil spring:
March 9th, 2009 12:13 AM #6
Rear suspension:
Front suspension:
Coil spring spacers sold by GlennSter (less than Php200/ea):
I forgot to check which end of the coil is up, but if you intend to put the spacer on the wider end of the coil spring, you will need Honda Civic spacers. 1993 Lancer spacers work for the narrower end. This is true for both front and rear coils.
March 14th, 2009 12:05 AM #7
The new Monroe shocks have arrived:
Part number front:
Part number rear:
March 14th, 2009 12:05 AM #8
Comparison:
March 14th, 2009 12:07 AM #9
Front Suspension:
Rear Suspension:
- Mar 2009
- 1
March 29th, 2009 12:11 PM #10[SIZE=5]Hello I am from Venezuela and also I have a Jimny 2002 that I want to raise 2", I want to know which are the corrects numbers of reference of the absorbers Monroe because those that you published are erroneous, they do not appear in catalogue, they are serial numbers, please search in the body of the absorber. Thank you I wait for your response...![/SIZE]
Tesla Philippines
