Page 319 of 320 FirstFirst ... 219269309315316317318319320 LastLast
Results 3,181 to 3,190 of 3192
    Nov 2019
    #3181
    Quote Originally Posted by Miles_on View Post
    Neither's mine. 3 yrs old and no issues whatsoever.
    Initial 2 PMS lang sa casa, the rest is OC owner self PMS strictly following the service manual, with full record documentation.
    I'm very happy with my little mud slugger and never plan to sell it.
    Yung sa full record documentation nyo po, sa service manual ng CASA nyo po ba nirerecord self PMS nyo?
    Sep 2021
    #3182
    No, I've a separate clear book and plastic envelope with receipts, arranged in proper sequence. (OEM filters/Engine Oil/OEM parts)
    I don't think I'll ever sell this though. On other, dedicated Jimny Forums, may mga 2nd gen. (SJ30 & SJ 40) pa rin sila that are still running up to this day.
    Feb 2014
    #3183
    i used to have android auto disconnection issues until i tried this. usb 3.0 to type-c adapter, and C-to-C cable. i don't know why or how it works but it just makes the connection 100% reliable for some reason
    #3184
    Quote Originally Posted by Vodka View Post
    Nov 2017
    #3185
    when i upgraded to R/T tires i replaced all five coz if you find yourself having to swap in your spare in a difficult trail you might not be able to get out having one highway tire in the mix
    but on pavement it should be fine. the stock tire is actually very close in diameter to 215/75r15. also it's not like it's something like a subaru that's sensitive to mismatched tires diameters...
    speaking of stupid... yung mga stock na naka 235, coz they will rub at extreme articulation. won't rub if you just drive to the mall
    I just replaced the OEM tires with Yokohama Geolandar A/T LT215/75R15. I put 29 psi and ok naman ride.
    Ano usually and tire pressure na ginagamit nyo or recommended on highway for this tire?
    Will try this tire on light trail this coming weekend.
    Feb 2014
    #3186
    Quote Originally Posted by Akky M View Post
    do the chalk test. i also got "LT" tires. turns out they needed to be 22psi front, and 18psi rear to get even chalk wear across the tread
    #3187
    I put 25psi on my BFG ATs
    I can go as low as 18psi
    Signature
    Nov 2017
    #3188
    Got it ! I started using 29psi and will adjust slowly to my preferred setting.
    I searched thru Australia and South Africa who are using a lot of 215/75 on stock rim and it ranges between 24-26 psi range. It could be depending on ply rating as well.
    PH, a lot of folks used the 235/75 on stock rims which I find too big (maybe its just me).
    Feb 2014
    #3189
    yeah it depends on how stiff the tire is. on my 50kg ebike i use a 4-ply rated tire and it only needs 8psi on pavement
    here's the chalk test on the rear tire at 18psi. it's actually still a bit overinflated. see arrows
    take note there's another effect going on here. as you mentioned it's the wide tire, narrow rim. tire tends to bulge the center tread if on a narrow rim. 215 is already wider than recommended for the stock rim by just a bit
    Aug 2024
    #3190
    Sir, tried your settings kasi same tayo ng tires.
    Very comfortable siya 100%
    Kaso parang bumigat manebela sa pag liko and bumigat acceleration niya.
    Hanggang ngayon ba ganun pa din PSI gamit mo ?
Suzuki JIMNY [merged threads]
