Results 21 to 30 of 56
- Jun 2018
- 1,475
October 12th, 2019 03:24 PM #21Yes, they will first check that your suspension is healthy. If not, they will not perform the alignment. That's SOP.
But they're good. Bridgestone Tire Center on Pasong Tamo is also good alternative.
October 12th, 2019 03:41 PM #22
Thanks SA maliwanag na sagot...
Pudpod kasi gulong ko SA harap naka negative na Yung gulong NG car na di masyadong ginagamit dito balak ko ipaayos, pinagawa ko na tie rod nun then Sabi ni mekaniko sur basag na wheel hub bearing.
naalala ko Lang balak ko kasi icamber alignment next week.
- May 2011
- 481
October 12th, 2019 05:20 PM #23when your vehicle has handling concerns, first you have your suspension checked for worn out, failed parts (analyze the cause of the part failure)
then have a prealignment check:
tire age, pressure, size and condition
ride height
wheelbase measured (both sides)
place the vehicle at curb weight (compensate lost fuel by adding a commensurate weight- 6 pounds per gallon)
then do the alignment routine:
rear camber
rear toe
thrust angle
front camber
caster
kingpin inclination
toe out on turns
front toe
over center adjustment
front wheel setback
steering angle sensor reset if applicable
anything less is just pretend and incomplete wheel alignment
October 12th, 2019 06:16 PM #24
- May 2011
- 481
October 12th, 2019 08:35 PM #26
October 12th, 2019 08:45 PM #27
October 12th, 2019 08:55 PM #28
October 12th, 2019 09:45 PM #29
^ pang formula 1 yatang alignment Yan mga sur [emoji1]
Ginagamit ko Lang pra bumili ng pandesal car naming extra kya ok na yung simpleng alignment Lang pambawas pudpod SA gulong
