Results 1 to 10 of 50
November 23rd, 2015 11:30 AM #1
My 2004 Mazda 3 has developed a rattle that can be heard when the rear left tire passes through a road imperfection. It sounds like there's something in the trunk that's bouncing around.
Of course, first thing I did was empty my trunk - rattle was still there. Then, I removed the jack, spare tire, and all tools, rattle was still there. I checked all clips, rattle was still there.
Next step was to have the suspension checked. I changed my shocks, but the rattle was still there. I even changed my stab links, but rattle remained (waste of money oh well). I also tried a new shock mount, new shock boot, and new lateral links, but the problem still persisted.
I already had 2 shops look at the suspension and both said that it was fine. So now, I'm quite stuck as I dunno what to check next.
One shop suggested that there might be some screws stuck in between the metal panels of the car that shakes around when passing through road ruts. Oddly enough, we can't reproduce the problem by bouncing the rear when it's stopped. You only hear it when the car is moving and the left rear tire passes encounters potholes.
If anyone has any idea on what the problem could be, or could suggest a shop that specializes on issues like this, I'd gladly appreciate the help. [emoji4]
- Jun 2005
- 3,774
November 23rd, 2015 11:36 AM #2My cousin had a similar problem but for a 2008 city. Car stayed weeks sa casa and also sa honda spa. Never found the problem.
Then dinala nya sa cruven. May naipit pala maliit na bato somwhere sa suspension arms. Tinanggal lang yung bato. Okay na.
November 23rd, 2015 11:46 AM #4
November 23rd, 2015 12:04 PM #5
Other things to look at is the trunk mechanism (hinge/latch), tailights, bumper mounts/clips... technically, everything that isn't welded on.
On older cars, body flexing or body panels moving against its mount because of flexing, can sometimes cause creaks and 'tick' noises when certain corners of the vehicle is subjected to stress.
This may sound funny and draconian but have you tried locking yourself or an assistant inside the trunk and have you/someone drive the car (carefully) over a pothole? That will help localize the source of the rattle. But do this in a controlled environment (parking lot, driveway, or a seldom-used street).
November 23rd, 2015 12:11 PM #6
Funny, but we actually tried that out of desperation. To be a bit humane though, I opened the 60/40 split rear seats to get some air into the trunk. [emoji16]
The guy isolated the noise to the left rear quarter panel. We tried checking all the suspension bits and they checked out fine.
- Jun 2005
- 3,774
November 23rd, 2015 12:17 PM #7
November 23rd, 2015 12:21 PM #8
What did the noise sound like (tick, bang, tok, etc.)? How do you reporduce it or what kinds of bumps/potholes does it respond to and at what speed?
Is it a one-time tick or does it dribble?
Describe it as detailed as possible.
November 23rd, 2015 12:24 PM #9
It dribbles, and I'm able to reproduce the sound when I pass through small road imperfections. I usually run over cat-eyes in the middle of the road to make the sound come out.
It sound a bit like putting a marble in a jar and shaking it. The sound comes out at any speed.
November 23rd, 2015 12:32 PM #10
You didn't mention about checking the brakes. It could be the brake pads rattling about (it could happen if it somehow didn't self-adjust or the brake pads have become worn out). Does the noise stop, continue or change in pitch while the brakes are applied?
If it's behind the quarter panel, I'd go one more step and remove the interior lining on that side. With a suitable mirror and a good flashlight, you should be able to visually see behind the double-wall. Or do it while driving the car one more time with your guy in the trunk.Last edited by oj88; November 23rd, 2015 at 12:34 PM.
Tesla Philippines
