Results 1 to 10 of 20
- Apr 2012
- 1
July 6th, 2013 06:38 AM #1Hello, hingi lang po ako ng advise and help. I noticed that my rear wheel wears uneven mas nauunang nauubos yung loob na part ng gulong kesa sa kabila. Kia Rio po yung oto ko at 2 years na sya 29000 na po yung mileage ng kotse. Anyone has the same experience? Please share naman po kung pano na ayos. Thanks.
July 6th, 2013 06:52 AM #2
July 6th, 2013 11:01 AM #3
August 6th, 2013 06:21 PM #5
Stop patronizing Hella Flush.
Check your wheel alignments and always the tire pressure. First time having a car? Be OC, treat it like your mistress (if already have a wife) or a GF. Rotate your tires every now and then.
August 6th, 2013 07:59 PM #6
Most likely a toe misalignment. If the wear is on the inner tread, naka toe-out masyado (negative toe).
In the off chance that there's no adjustment for toe in the rear axles, check suspension bushings and hub bearing for play.Last edited by oj88; August 6th, 2013 at 08:01 PM.
August 8th, 2013 08:51 AM #8
Naka negative camber ang ride mo - pinapang drift mo ba?
Toe alignment applies to the front tires (parang pike or sakang).
http://www.myfiatworld.in/attachment...1&d=1333361291Last edited by Phoenix67; August 8th, 2013 at 08:54 AM.
August 8th, 2013 09:25 AM #9
Wrong.
1. Toe misalignment contributes more to uneven tire wear than camber misalignment. With an incorrectly set toe, the tires are technically rubbing/scraping the pavement instead of just rolling over it
2. Toe alignment applies to ALL tires. The question is more on whether the rear tires' toe alignment on a particular car is adjustable (usually it is). If not, there may already be some serious damage to the suspension, like if it was subjected to an impact (ie. deep pothole at a high enough speed), putting it permanently out of whack.Last edited by oj88; August 8th, 2013 at 09:42 AM.
August 8th, 2013 10:53 AM #10
Tesla Philippines
