Results 1 to 10 of 25
- May 2012
- 137
August 9th, 2012 10:27 AM #1Hi!
Has anyone tried this product?
## TTC Polyurethane Cushion ##
I would like to know if this has improved the ride of your vehicle(s). It is kinda expensive, but I've not read any reviews, so I am quite curious... perhaps it will be good for my Suzuki Jimny...
Thanks.
Jaime
August 9th, 2012 10:53 AM #2
sir, parang katulad din yan ng o-sulee spring cushion, sa akin lang ha, not worth it
- Jul 2008
- 479
August 9th, 2012 04:27 PM #3na try mo na sir eto or o-sulee? am planning to install o-sulee sa rear coil spring ng santa fe ko para di mag bottom out if puno ng passengers (7). kasi pag 7 passengers na, bottom out na rear end ko ang mas mataas na front end niya. will this problem be solved by installing this? thanks
- May 2012
- 137
August 15th, 2012 10:36 AM #4Saan po nabibili yung O-sulee?
Are there any other brands available out on the market? Preferably cheaper?
Any other inputs, experience?
August 15th, 2012 10:50 AM #5
meron pa ibang brand na taiwan din. clear polyurethane sya. i forgot the brand. o-sulee madami sa banawe yellow orange poly sya
- Aug 2012
- 1
August 16th, 2012 04:05 PM #6at available din ang o-sulee spring cushion sa blade asia / true value at handyman
- May 2012
- 137
August 28th, 2012 10:31 AM #7I found out that O-sulee is about P1,700 a set for 2 wheels/coilsprings. Also, it is made of rubber and meant to last only 2-3 years.
While polyurethane is meant to last 10 yrs "daw." ... Still on the fence about this; may try a pair for either front or back muna.
- Jul 2008
- 479
August 28th, 2012 04:13 PM #8available na ito sa Road FIt (banawe and visayas ave). saw it also sa PIMS. Mukhang better performance and durability versus O-sulee. Not sure lang how well it will imporve the ride. kinda expensive at 4K per wheel versus o-sulee na 2k. meron din sila china brand, red rubber at 1.4k. some say nag improve ride nila. my boss installed o-sulee on his Gen 2 CRV initially sa rear. not much improvement. but when he installed also in the fornt, he said vastly improved daw ang ride nya.
am still thinking hard if i will install a pair on my ride. more inclined to install the coil rite since many santa fe owners are happy with the improvement.
- Jul 2011
- 262
November 13th, 2012 12:54 PM #9ups ko lang po pede kaya ito sa kia pregio ko.. kapag puno kami..bagsak na masyado yung likuran ko..kung baga parang eroplano na tume-take-off ;-(
any expert/experienced opinions/comments are welcome
TIA
November 13th, 2012 01:41 PM #10
Improvements po nya in terms sa play ng shocks and spring, less bouncy and may resistance compare sa wala. It doesn't add height to your ride kung yun ang hanap nyo, this is not the product your looking for. Pero kung ayaw nyo ng matagtag, this one is recommended.
Tesla Philippines
