Results 1 to 10 of 43
jimaroquai TPMS (Tire Pressure Monitoring System) November 18th, 2006, 05:19 PM
OTEP Re: TPMS (Tire Pressure Monitoring System) November 18th, 2006, 05:22 PM
oliver1013 Re: TPMS (Tire Pressure Monitoring System) November 18th, 2006, 08:13 PM
nugundam93 Re: TPMS (Tire Pressure Monitoring System) November 18th, 2006, 08:55 PM
adventure Re: TPMS (Tire Pressure Monitoring System) November 26th, 2006, 07:00 PM
blued888 Re: TPMS (Tire Pressure Monitoring System) March 4th, 2011, 04:58 PM
jick.cejoco Re: TPMS (Tire Pressure Monitoring System) March 4th, 2011, 09:45 PM
blued888 Re: TPMS (Tire Pressure Monitoring System) March 4th, 2011, 10:16 PM
beni23 TPMS (Tire Pressure Monitoring System) November 30th, 2012, 09:44 PM
April_Ryan TPMS (Tire Pressure Monitoring System) November 30th, 2012, 10:37 PM
ice15 Re: TPMS (Tire Pressure Monitoring System) August 3rd, 2020, 03:35 PM
oj88 Re: TPMS (Tire Pressure Monitoring System) August 3rd, 2020, 04:34 PM
sirkosero Re: TPMS (Tire Pressure Monitoring System) August 3rd, 2020, 10:44 PM
teukie Re: TPMS (Tire Pressure Monitoring System) August 3rd, 2020, 06:44 PM
oj88 Re: TPMS (Tire Pressure Monitoring System) August 3rd, 2020, 10:12 PM
baludoy Re: TPMS (Tire Pressure Monitoring System) September 13th, 2021, 09:20 AM
    Yung sa Paj FM ko di na accurate iba iba ang reading kahit iisa sukat sa pressure guage sa gas station.
    the first mitsu to carry this was the fieldmasters. anyway, yes, it is inaccurate but it can still help show you if a flat suddenly occurs, based on personal experience. i think winterpine is the one supplying mitsu philippines with this.
    yung sensor for each tire attaches to the end of the air valve that goes into the inside of the rim.
    Aug 2006
    mga sir tanong ko lang po sa mga may TPMS diba po kapag nawawalan ng signal ano po ba puwede gawin kasi po naka ilaw lang at nagiinit puwede po ba bunutin yun o kng ano po puwede gawain
    Dec 2010
    Anybody know anything about the ones in Toyotas? Bagong option lang ata ito, sells for around P12,000.
    Feb 2009
    the tpms is the whole system. if you need the in-tire sensor, you need to replace all four if you can not find the exact replacement. most of them need to be reprogrammed while installed on the car with a special sensor "training" tool to synchronize the frequency with the cars signal receiver
    Dec 2010
    Are these sensors very prone to damage when changing tires?
    So it has to be reprogrammed each and every time particularly when you change tires? Can this be done by the user/owner or the casa alone?
    I've read that Mitsubishi's TPMS can be reset by the user/owner.
    Feb 2009
    the tpms sensor is sensitive to water in the tire from undry air supply tanks. it is also sensitive to the "fix-a-flat" tire sealer/inflator. if the tires had to be replaced, the sensor does not retraining. the tire technician should be very careful though as these sensor/transmitter are susceptible to damage when demounting and mounting tires
