Results 1 to 10 of 10
    Oct 2014
    Gud AM Tsikoteers. what could have been the cause of the leak (See pic) could just be a bushing at the inner tierod or in the Rack in Pinion? And your recommended shops here in Imus-Bacoor area. Click image for larger version.
    Sep 2014
    Palit buong assembly yan if wala repair kit
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Oct 2014
    You mean Rack and Pinion assembly ba Bro.
    Quote Originally Posted by Gian Paulo View Post
    kung hindi kayo nau-ubusan ng PS fluid, that black rubber accordion-like thingee lang siguro.
    kung gagananciahin kayo, yung rubber boot lang ang dapat palitan.
    hassle lang, dahil maraming tatanggalin para lang ma-abot yan. mas mahal pa yata yung labor kaysa piyesa, if my poor memory serves me right...
    Tingin ko rack and pinion Yan. Wala naman ibang pngalingan ng PS fluid. Kung hinde nauubos fluid mo siguro konti-konti lang bawas Pero sa katagalan naipon sa boot Kaya Hinde mo.nakikita napuno na boot ng fluid Kaya lumabas, if sobrang konti lang bawas kung Wala lang budget then have the boot replace muna. Bantayan mo na lang fluid level
    Pag napunit Yan boot labas lahat Yan makkikita mo sigurado leak sa sahig
    Oct 2014
    Evaluation ng Servitek repair kit daw. Nakabili Mitsu OEM P3300 sa MitsuPrime Imus. Mahal lang ang Labor P3000 plus pa ang alignment. Ipagawa ko sa Sunday.
    Oct 2009
    diba kaya dukutin muna yang isang side na may leak ?pareho bang may leak.
    Jul 2006
    There are seals on both ends of the rack. These seals keep in ATF. If already worn, they will permit ATF to leak outside.
    Sep 2014
    Kasama na ba P/S fluid dyan 1L, i think you need to replace the entire contents of the fluid too and labor as well
    Oct 2014
    [QUOTE=minicarph;2764627]Kasama na ba P/S fluid dyan 1L, i think you need to replace the entire contents of the fluid too and labor as well
    Di pa kasama Bro. They listed 250 for that and yung wheel alignment medyo P1500 additional pa.
Leak. Inner Tierod or Rack and Pinion.
