Results 31 to 33 of 33
July 25th, 2007 05:59 PM #31
i do the rotation myself every 10k, i'm planning to make it every 5k (kung sipagin). ganda kasi ng result when you rotate, i always end up buying 1 set of tires in a span of 4-5 yrs. ang sarap pa magpa-align pag 4 new tires, alang kabig talaga
Tsikot Member Rank 3
- Aug 2003
- 1,251
July 25th, 2007 10:27 PM #32better if you can include the spare tire in the rotation. If not, then rotate the 4 tires. But when you replace the worn out tires, you must use the spare tire among the 4 because the rubber in the tire only has a recommended life span of 5 years. Beyond that, tires, especially the sidewall, has tendency to become brittle or less flexible.
July 26th, 2007 12:09 AM #33
to those without manuals, here is the schematic diagram i copied from a chevy colorado manual:
tire rotation without using spare
Front
O O
1 2
O O
3 4
1 goes to 4 , 4 to 2, 2 to 3, 3 to 1
tire rotation including spare tire
Front
O O
1 2
O O
3 4
O
Spare
this is a little bit complicated...
Spare to 4, 4 to 2, 2 to 3, 3 to 1, 1 becomes the spare
HTHLast edited by lolo pepe; July 26th, 2007 at 12:20 AM. Reason: me pinalitan
