Results 11 to 20 of 23
May 16th, 2003 10:27 AM #11
I use Dunlop FM 901 195/55/R15 ang recommended tire pressure(when tires are cold) ay 32psi sa front at 30 psi sa rear, usually nakadikit yung mga recommended tire pressure sa gilid ng door panel.
- 10,620
May 16th, 2003 06:44 PM #13
ano recommended sa 31x10.5-15" All Terrain Tires nakakabit sa 3 Door Pajero.
December 7th, 2006 11:34 AM #15
anong recommended pressure ng 205R60 14 Falken?
ang gamit ko kasi 35 eh. pero parang malambot pa din.
December 7th, 2006 12:04 PM #16
- Dec 2023
- 26
January 6th, 2024 12:40 PM #17I never understood the reason for the switch to wider, lower profile(sidewall) tires on larger rims, but generally, required cold pressure increases with them to:
1. Maintain even contact patch across a wider tread
2. Support the shorter sidewall to maintain rim edge above the pavement.
The increase in cold pressure is typically 1-2psi per inch increase in rim diameter.
- 53,883
January 6th, 2024 01:35 PM #18
- Dec 2023
- 26
January 6th, 2024 01:59 PM #19
January 6th, 2024 02:02 PM #20
I would love you to meet my friend *travajante kayo dalawa magusap . [emoji23]
