Results 1 to 10 of 12
- Apr 2010
- 47
February 11th, 2014 08:11 PM #1Hi, mga sir's ask ko lng po kung ano magandang gawin sa sobrang lambot na rear suspension springs, kc madalas ko napapansin na sumasayad ung body sa gulong pag may lubak or road humps, ano po ba magandang gawin remedy dito? TIA.
- Jul 2011
- 1,711
February 11th, 2014 09:44 PM #2Baka naman wala na ung shocks mo, pa lift mo para makita kung buo pa.
February 11th, 2014 11:08 PM #4
baka mabilis ang rebound kamo sir TS at hindi malambot.
kung sumasayad na, kadalasan nanghihina na mga springs. ang shock absorber e anjan para icontrol lamang yung pagrebound ng sasakyan.
- Nov 2010
- 369
February 12th, 2014 03:30 PM #5Pacheck mo shock absorber. If okay naman, add ka na lang rubber lifters (donut shape) para tumaas. Thats the cheapest way to do it. Just dont buy yung rubber na sinisingit lang sa springs.
- Aug 2013
- 475
February 12th, 2014 07:23 PM #7
- Jul 2003
- 573
February 13th, 2014 12:39 AM #8there is supposed to be a rubber stopper that will prevent the shocks from bottoming or the tires from hitting the fender under extreme load or bumps. make sure the rubber stopper is still in good condition.
February 13th, 2014 08:49 AM #9
over time, as the car ages, some suspension components get tired. be it torsion bar springs,coil springs, leaf springs and specially air springs. if the gross weight of the car far exceeds that of the rated weight without upgrading the springs, the springs go into accelerated "tired" height. it does not matter if you change the springs to the same oem type if the gross vehicle weight is too much, it too will have the same effect. maybe your passengers are too "healthy"
- Apr 2010
- 47
February 13th, 2014 09:15 AM #10thank you po mga sir's sa reply btw po the car is a honda city i-dsi, will have the springs check pra matignan ko na din ung rubber nya thanks po...
Tesla Philippines
