Page 1 of 3 123 LastLast
Results 1 to 10 of 32
    Apr 2006
    Chief,
    I have a Honda Civic 1.8S AT and I am experiencing steering wheel vibration when breaking at high speed (140 - 150 kph) which normally doesn't appear when breaking at a lower speed. I have the casa qc technician check it out through a test drive with me 2 days ago. And after experiencing it himself, he concluded that it is just the ABS working. Mga chief; is this correct? Does anyone experience the same vibration when breaking at high speed? Thank you for your replies.
    Sep 2005
    roky
    I have the same problem. Mine occurs at 120kph up. My car is an 89 galant supersaloon and absolutely got no ABS At first i suspected my front brake rotors to be the culprit but when my mechanic inspected it, its in perfect shape (smooth even surface) He suggested to have my wheel balanced on a hi speed wheel balancer (meron ba nito sa manila?) as of now, my quick solution is not to go faster than 120kph
    Quote Originally Posted by smalltimer View Post
    roky
    I have a honda civic 2001 vti-s also mine occurs at 120 kph, casa inspected my rotors and they said it was fine plus my disc pads are also ok. they also it was the abs working but i know it's not the abs.
    Apr 2006
    Sounds like some BS to me. Braking vibration might be caused by deformed/warped front brake rotors. Usually when the ABS activates, the brake pedal vibrates and NOT the steering wheel.
    Yeah, it sounds like BS to me too. They have checked my rotors and break pads, and they said that it is still within specifications.
    Quote Originally Posted by VtEC View Post
    I go with this or replace your tyres bro baka gastado na mga yan.
    Sir, OK pa yung tires ko. They checked my alignment and they have balanced my wheels, pero the vibrations still came out when breaking at high speeds.
    Quote Originally Posted by Lim 88 View Post
    Good to know I am not alone. I think it's not really normal for the steering wheel to vibrate during high speed breaking. I have experienced the abs working when sudden breaking but it is different from what i have experienced when breaking at high speed.
    Jul 2015
    Quote Originally Posted by roky View Post
    i have the same problem about a week ago... i have done some research here is what i got.
    Top 5 Reasons Your Car Is Vibrating - HowStuffWorks
    as it turns out the culprit is the rack end and tie rod...
    my pinion also have a busted oil seal...
    got it fix at around 15k plus.
    Feb 2009
    vibration at certain speeds is usually caused by dynamically imbalanced tires. bent wheels, worn out tires, loose steering components (tie rods. loose rack and pinion assembly mounts, worn out wheel bearings) but believe it or not: dragging brakes will cause these symptoms.
    Feb 2009
    Chief,
    naku sakit yata ng mga new civic yan. sa akin kakukuha pa lang sa casa (2 mos ago) me vibration na. tinest ko sa NLEX hayun nanginginig. sabi ng honda "dalhin nyo po sa & aayusin namin". sayang na naman ang oras, oh well.
    bawal mgpakabit ng fog lamps & front & rear sensors sa banawe, void daw warranty. sisi tuloy ako
    try alignment and balancing. hth
Steering Wheel Vibration
