Results 1 to 5 of 5
April 27th, 2013 12:32 PM #1
Guys ano kaya problema.. kasi may play yung steering wheel ko.. pag inikot onti papuntang left from straight position.
parang 1inch yung play.. kanina pinaayos ko yung centerlink ko pero ganun pa rin.. ano kaya culprit?
- Jul 2003
- 573
April 27th, 2013 05:01 PM #2baka preload adjustment ang kailangan niyan.
pero check mo din kung may play na ang rack ends o tie rod ends.
April 27th, 2013 05:09 PM #3
April 27th, 2013 09:11 PM #4
first, since the subject vehicle is not properly identified, it is safe to assume that it has parallelogram type steering.
you mentioned centerlink that makes it not cross steer, not haltenberger, not rack and pinion, not centerpost type steering.
check your idler arm and pitman arm, or perform a dry park test (done with another person feeling the linkages for looseness while another person turns the steering wheel back and forth slightly)
April 27th, 2013 11:16 PM #5
salamat sa mga reply
kanina kasi tnest yung steertimg wheel.. inikot ikot tapos nakita yung sa center link daw loose so yun ang inayos..
okay pa daw yung tie rod..
anyways isuzu ls yung kotse ko.. sabi ng isang mechanic baka daw crossjoint?
Tesla Philippines
