Results 1 to 8 of 8
- Dec 2009
- 20
March 2nd, 2012 10:28 PM #1Tsikoters,
Plano ko sana bumili O-Sulee spring cushion for my hyundai getz 2011.
Purpose: Ride comfort and more stable in cornering.
Meron na ba sa inyo gumagamit nito? any feedback po? Thanks.
March 11th, 2012 10:11 AM #2
Just an FYI, this will void your suspension warranty. Installation and removal is easy so be sure to remove bago pumunta sa dealer for your PMS.
I have installed O-Sulee on both my rides, a Suzuki APV and Suzuki Esteem. Installed it in my APV to supposedly lessen the "tag tag" and tigas ng suspension. Unfortunately, halos walang difference sa ride. My APV rides on 16" mags. My Esteem is 1.5" lowered via H&R lowering springs on 17" mags. Dito merong difference as di na sya masyadong sumasayad even when loaded. Sa rear ko lang nilagyan ng O-Sulee kasi medyo naka-tingala yung ride ko. Medyo gumanda rin ang stance since pantay na yung bagsak ng harap ang likod. Lumambot din suspension and halos comparable na ang ride sa OEM pero syempre mas makapit sya ngayon specially on corners. I would recomend O-Sulee on lowered rides only base on experience.
HTH!
- Apr 2010
- 57
May 15th, 2013 03:52 AM #3CMIIW pero using o-sulee, makes your ride "stiff" dahil mas may laban na yung springs mo with it's help while at the same time nakakabawas siya ng tag tag dahil controlled niya yung play ng spring. Tama po ba intindi ko? Planning to lower my ride kasi then install a set of these.
May 15th, 2013 03:05 PM #4
Lowering your car will already stiffen your ride. If you lower with lowering springs, no need for spring inserts. If you lower by cutting springs (which I advise against), adding inserts like O-Sulee will merely magnify your problem. Instead of having, say, eight coils of spring to absorb bumps, by cutting, you're down to six, then add inserts and you're down to four... your ride will be pretty... well... terrible.
- Apr 2010
- 57
- Mar 2012
- 95
October 17th, 2013 11:43 PM #6been using O-sulee for almost 2 yrs now in my innova. ok naman siya. pag biglang brake, hindi siya sumusubsob. yung sa likod, tinanggal ko, nagalit si misis. masyado kasing matagtag.
Tesla Philippines
