Results 1 to 9 of 9
    Car is CR-V gen 3. Tires are westlake SU318. Almost 2 months old.
    Kagabi i noticed na parang i'm running flat sa front right pero when i checked the tire, ok naman. May "thud" sound na nag increase din ang tempo when i accelerate.
    Nag drive kami to sagada coming from QC last weekend. Nung monday, wala pang ganon. Kagabi ko lang naramdaman.
    Ano kaya problema? Di ko pa nakikita yung inner part kung may bukol.
    Hindi kaya't oblong ang tire mo or nagkabengkong ka?
    Does your steering wheel vibrate as well or pull to one side?
    It's hard to diagnose a wheel/suspension issue without having an actual road test, so it would really be best to take it to a nearby Servitek or whatever your favorite tire/suspension shop is so that they can diagnose. You can always go for a second opinion elsewhere if you're not satisfied with their diagnosis and quotation.
    Safe driving bro. [emoji106]
    Ayos sir jutz. update ko thread pag ma observe ko mamayang gabi. weekend pa kasi ako makakapunta sa shop.
    Oct 2009
    baka may umipit lang na bato kasi bago pa at makapal pa ung spike
    Quote Originally Posted by jaypee10 View Post
    check ko mamaya sir. sana nga ganyan lang.
    It turns out na yung ingay is coming from the back right side. Yun yung pinalitan ko ng spare tire. Bago din yung spare. Baka hinde ko na mount ng maayos. Check ko ulit pagpa vulcanize ko bukas.
    Mar 2004
    Check the thread wear ... might be toe in / out problem ...
    Quote Originally Posted by robot.sonic View Post
    put back the old tire. if the sound disappears, then we know it's that spare tire... probably a manufacturing defect.
    Problem solved.
    Nagpa vulcanize ako ng tire and then swap sa rear right. Andon pa din yung "flat sound".
    Dinala ko sa motech. Checked the brakes kung may issue. None. Pero nakita na busted na yung rear shocks.
    Changed rear shocks. Habang naka lift yung oto, nakita ko na may bolt na nakatusok sa front left. Ang hinala ko ay yun yung cause. Di ko muna pinalitan kaagad ng gulong to check my theory. After replacing the shocks (both sides), yung vibration ay lumipat sa front left. Since sira ng yung rear shocks, yung vibration caused by the bolt ay hinde na ma damp ng shocks kaya dun nararamdaman.
    Pagpalit ko ng spare tire sa front left, nawala ang vibration.
    7K total damage.
Sound and feels like a flat tire
