Results 21 to 30 of 40
April 10th, 2012 05:34 PM #21
update: nawala yun grinding sound after ko palitan ng hardware kit.
sana maganda ang result. obserbahan ko parin. thanks sa mga input guys.
April 20th, 2012 02:27 PM #22
as usual bumalik nanaman yun brake noise. oh well. hopeless na talaga auto ko
April 22nd, 2012 09:30 AM #23
- Aug 2009
- 178
April 22nd, 2012 01:22 PM #24having the same predicament with my 7g galant. almost all in the previous threads were done but to no avail. maximum tolerance to date, hayyyz.
April 22nd, 2012 07:34 PM #25
nag research ako sa net.. since may ABS yun sentra ko..pwede din daw panggalingan ng sound yun.. pero pano ko malalaman na sa abs ang culprit?
*9701
ganyan din ba problem mo?
April 23rd, 2012 04:18 PM #26
April 24th, 2012 08:12 AM #28
you described two noises. is it both screeching and grinding? using common household noises, use a good known similar noise for comparison. check beyond the brakes if you have tried most of the common brake repair procedure. it might be worn out suspension bushings or wheel bearing that is making noise. do a visual inspection if there are metal shavings around the suspected noise area. check for tightness of the fasteners that may have been disturbed. insufficiently torqued fasteners make that noise. the mating surfaces between the rotor and the hub must be free of debris. the mating surfaces between the caliper bracket and the steering knuckle must also be free of debris and torqued to specs
April 24th, 2012 04:11 PM #30
