Results 1 to 3 of 3
    Jul 2010
    Kumakabig kasi sa kaliwa yun kotse. Lalo na kung mabilis. Tagal ko na problem ito. Hindi mahuli huli ng Zafra sa Banawe. Nasa passenger side rear wheel pala problem. Pero di ko makita yun sinsabing control arm adjustment para ako na lang mag adjust.
    Feb 2009
    Quote Originally Posted by Chinoi View Post
    on the inboard end of the aft lateral link, there is an eccentric cam provided to adjust rear toe. your specs calls for 3+/-- 2mm toe in. check the camber first at 0*55' =/--30' after doing all the pre-alignment checks
    Jul 2010
    *jick.cejoco
    Thanks for the replay. Just downloaded service manual for Mitsubishi Rear Suspension. Able to locate Control link eccentric bolt adjustment. I have to push the farthest end inward of Lower Arm to be able to align my rear wheel and tightened the eccentric bolt. The Eccentric plate was broken.
Saan ba in-adjust ito na toe out yun rear wheel ng Lancer EL?
