Results 1 to 2 of 2
- Jun 2012
- 5
June 15th, 2012 10:54 PM #1Last time i had all my dampers changed i opted to install lifters at the rear end of the car to get some height before getting my audio set-up. Prevent the car from going to low after having additional load from the woofers, amps etc. Is this a good practice and would this have any adverse effect on the overall performance of the the car suspension?
Tsikot friends please advice....
June 15th, 2012 11:19 PM #2
Although you have "lifted" the car's suspension, it still does not reduce the added weight.
In the medium to long term, the springs will sag/compress and the shock/dampers will wear out sooner than later (due to extra work they have to do with the weight of the amps/speakers/box. The same goes for the rubber bushings in the rear suspension.
Also, your car's fuel economy will go down and the brakes will wear out a bit faster with all the extra weight you are carrying.
