Originally Posted by
LN106G
you can upgade a little higher with thailand-made RUNSTOP slotted and cross-drilled rotor discs. If budget is not a problem, then upgrade to higher or better brands (Brembo, DBA, EBC, etc). The cross-drilling &/or slotting of which dissipates heat better than standard rotors. Stopping power is also better. But OEM - spec is ok for most as majority don't use their cars for racing. I am not also fond of refacing as this is just a remedy & a "patch-up" job. Changing your warped &/or thinned-out rotors discs with a brandnew one (OEM, OEM-equiv or upgrade) and brandnew brake pads is the way to go...
Tesla Philippines
