Results 1 to 10 of 22
- Jul 2014
- 31
September 23rd, 2019 09:55 AM #1guys, help po, pa-locate kung my thread na po para dito sa problem ko. My encountered lagatok ako kapag na-break po ako. kapapalit ko lang din ng tie rod, rack end and stabilizer, pero same pa din. kapag mabilis takbo wala nman lagatok kapag na-break pero kapag slowdown like trafffic don ko lagi nadidinig ung lagatok sa break. pwede po kaya malaman ano pa other issues? 5 yrs car unit honda brio 1st gen owner.
salamat po ng marami.
- 53,883
September 23rd, 2019 10:05 AM #2may lagatok na ba, before you replaced your tie rod, rack end and stabilizer?
if the lagatok appeared only after the replacement, then you have your answer.
is it possible, the sound has nothing to do with the suspension and steering system, but with the power train or engine support?Last edited by dr. d; September 23rd, 2019 at 10:09 AM.
September 23rd, 2019 10:35 AM #3
engine support?
brake caliper not installed properly after baklas?
brake pad na manipis?
btw mabilis or mabagal nalabas yun lagutok?
- Jul 2014
- 31
September 23rd, 2019 10:46 AM #4
- Jul 2014
- 31
September 23rd, 2019 10:50 AM #5
pina-check ko din po brake pad sabi skin makapal pa din, pina brake cleaning ko na din ganon pa din.
paano po ba checking sa engine support?
kapag mabagal lang po, my lagutok,my tug-tug na sound po kpg pinepreno ko.
sabi sakin ung shock mounting ko kailanga na daw palitan. hindi ko sure kung related un sa lagatok kapag na-break . any thoughts po.
September 23rd, 2019 12:46 PM #6
hmmm... angat mo yung tire tapos try mo igalaw yunbg tire...
left right tapos up and down... try mo pakiramdaman
September 23rd, 2019 12:58 PM #7
September 23rd, 2019 04:00 PM #8
Brake pad. Yung innova ko dati ganyan problem nung pinalitan ko ng replacement na brake pads. Nung binilhan ko ng OEM, back to normal na.
- Jul 2014
- 31
September 23rd, 2019 04:54 PM #9
- Jul 2014
- 31
September 24th, 2019 11:57 AM #10ngyon ko lang narealized na mali pala spelling ng brake ko. hahaha. thanks guys, papa diagnoese ko nlng sa shop ung problem, atleast my idea na ko ano ano papacheck ko sa auto.
Tesla Philippines
