Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jan 2012
    Good day to all tsikoteers! First, I would like to inquire, san po ba maganda magpaayos ng front wheel bearings and hub bearings (back)?
    Second, problem is, noong bumili ako ng gulong, nagpa-align at nagpapalit ng axle outer boot, ang sabi sakin nung mechanic, stock-up daw po yung part na pinagpapalitan ng bearing o yung housing nung bearing, kailangan pa daw po initan o pa machine shop para mabuksan at humiwalay yung assymbly.
    Meron po ba kayong alam na aftermarket service shop and one stop shop na gumagawa ng ganito aside from bringing it to casa na kumpleto na ang service at one day lang gagawin?
    Ride is Hyundai Getz 1.3L Petrol
    Thank you very much.
    Sep 2012
    Quote Originally Posted by Boy Tilaok View Post
    Sir, if ever kaya mo naman papalitan na lang instead of machine shop much better. For safety reasons na rin kasi wheel bearings yan eh.
    Just my two cents
    Jun 2011
    any goodyear servitec sir....
    talagang kailangan ipress out and in sa machine shop po ang ganyan...
    May 2009
    kung stuck up na eh di na naikot. mapuputol spindle nyan. cold chisel o matibay tibay na screw driver at martilyo katapat nyan para matanggal at mapalitan.o kaya hugutin ng nakakabit ang spindle nut sabay hugot yung disc assembly.
    Jan 2012
    Sir nag canvass na ako yesterday mahal siya, aabutin ako ng mga 8K for the 2 front wheels. Bale 4K halaga ng isang assembly. But anyway sir, thank you for the advise i will consider this and bring it as my first option.
    Jan 2012
    Sir Glenn, thank you po, but I have to make sure first if they can do it and also the price in doing it.
    maybe you should seek another mechanic for another opinion. i can not imagine na-drive mo pa yung kotse kahit stuck up na yung bearing/wheel spindle assembly.. maybe he was trying to say something else, but this is what he said instead..
    Aug 2004
    Mahal naman ata. We were able to replace the front bearings of a Lancer for mga 3-4k total kasama na press in and out. DIY nga lang pagtanggal namin ng hub so nakamura kami onti sa labor. We had the bearings pressed at a big machine shop malapit sa AAP sa ilalim ng LRT2 Gilmore station. Make sure they use the correct grease.
    +1 ako dito. Wala ka bang ugong na narinig or vibration sa manibela while driving?
    Jul 2010
    Mura palit wheel bearing para sa Lancer EL itlog. 1,400 gastos ko. Palit 1 front wheel bearing, 2 oil seal, rubber boot, axle grease at labor na 300.
    Nagpapalit din ako ng 2 rear wheel hub. 750 ang 555 brand. Maugong na kasi mga 4 bearing sa kotse. Nalubog kasi sa baha.
    Kung maugong na bearing mo ay magugulat ka pag napalitan ito ng mga bago. Tipid uli sa fuel kotse mo. Para ka kasing partially naka handbrake pa pasira na wheel bearing.
    Jan 2012
    Another thanks for the replies, mga sir, napacheck ko na siya wala namang alog yung two front tires. In my observation, meron na akong naririnig na humming sound while I'm running, speed is aroung 50-60 kph hindi ko po alam kung yung humming sound eh galing sa bagong bili kong gulong o sa wheel bearings na. Pero I suspect na sa bearings na galing yung sound.
    Siguro mga sir, ang hihingin ko nalang eh yung mga list ng mga reliable shop na pwede ninyo mai-recommend. I'm from Mandaluyong, kung meron po sanang malapit na shop sa amin.
    Again, thank you po sa inyong lahat.
Wheel Bearing
