Results 1 to 10 of 21
- Feb 2009
- 15
March 2nd, 2009 10:12 PM #1Hi,
Need your expert advise on my Corolla SE 95. Just recently I noticed oil leaks coming out from right side of the power steering assembly, specifically from both the side of bellows. The leak is minor but I need to refill the steering fluid after a week or two of driving.
Can somebody advise how to fix this? The car shop I had asked said that we need to replace the whole assembly: the rack and pinion and power steering pump plus repair kit. Is this the only way to fix this?
Thanks in advance.
March 3rd, 2009 01:26 PM #2
imho, repair kit lang yan...
you would only need to replace the assembly kung sira na yung pump.
- Sep 2007
- 215
March 4th, 2009 11:09 AM #3you have to replace the repair kit of both rack and pinion and sa power steering pump ... that will cost you about 2800 orig sa rack and pinion kit, another 1100 orig sa power steering pump and labor of about 1900.
If you like a remedyo is to buy the oil seal lang not the whole kit. It will cost you about 950 orig na. Tapos yung powersteering pump 1100 talaga and labor is abot 1800- 1900
BANAWE AUTO SUPPLY
regy
BANNED BANNED BANNED
- Jul 2003
- 2,267
March 5th, 2009 08:03 PM #4kung wala ka pa budget, try mo muna yung leak stopper like cyclo lalo na kung ndi pa malakas. then ipon-ipon ka na for the repair kit. always buy the OEM.
March 5th, 2009 08:26 PM #5
March 6th, 2009 08:01 PM #6
i think my steering too has symptoms of leaks coming from inside the dust boot. saan po kaya makabili ng cyclo leak stopper? how much po kaya iyon? parang madalang if not wala siya sa mga oto supply dito sa laguna.
- Jan 2009
- 393
March 6th, 2009 08:48 PM #7handyman at waltermart sta. rosa used to have it. otherwise you can check blade at sm. sta rosa. or ace hardware.
- Mar 2009
- 7
March 7th, 2009 11:03 AM #8bro wag kang papayag na palitan ang buong assembly!! car kit lng ktapat nyan...
- Feb 2009
- 15
March 10th, 2009 12:58 PM #9Hi Guys,
Thanks for the replies. Im a newbie with regards to car engines so I appreciate your inputs. I will have it check with
other shop for their opinions.
More power to Tsikoteers!
Regards...
- Apr 2009
- 14
April 17th, 2009 05:05 AM #10hi po mga bossing. i have accord 96 exi. newbie rin po ako when it comes to cars.
however. i have 4 questions, i hope you guys can help me.
may nakikita po akong leak sa garage kulay pula po. Looks like ATF ( kasi napakita na po sakin dati ng mekaniko ang ATF fluid). * 2 different spots po. pina check po namin sa YOKOHAMA along sa commonwealth diliman quezon city malapit po sa MALVAR gen hospital. sabi po ng mekaniko sa RACK AND PINION daw po tagas. OVERHAUL daw po ang gagawin.
binigyan po ako ng estimate of 9,500 pesos.
question is ;
1. tama po ba ang estimation nila ng price of 9,500 pesos?
2. may masmababa pa po bang price na pwede ipagawa ang tagas? kung meron saan po pwede puntahan at sino po pwede hanapin?
3. kelangan po ba talagang ipa OVERHAUL ang RACK and PINION o may simpleng paraan po ba para mawala ang tagas?
4. (not relevant to the topic) nagpalit po ako ng upper ball joint, magkaiba po ba ang lower ball joint sa upper ball joint?
ok naman po ang pag liko wala naman po bigat (steering)Last edited by roi0431; April 17th, 2009 at 05:10 AM. Reason: additional message
Tesla Philippines
