Page 6 of 6 FirstFirst ... 23456
Results 51 to 59 of 59
    Jan 2011
    #51
    No sir, the PS boots will not stop the fluid leak, the PS boots is only a cover para hindi pasukin ng dumi yung gear, sira na din siguro yung PS boots kaya na advice ka na palitan yung ps boots, repair kit or gear box yung pwedeng maging cause ng leak
    #52
    you can also visit cruven cubao branch.
    sila gumawa ng leaking rack and pinion ng 2000 civic vti ng misis ko three years ago.
    Oct 2009
    #53
    good day mga boss, my car is honda city type z 2000 model. im also having some problems with the power steering, i had my steering pump overhauled about almost a year ago, because of the leak. it was then fixed but recently i have been experiencing a loud humming sound when i turn the steering wheel left or right. pinacheck ko sya ang sabi is the pressure hose. may kamahalan ang pressure hose ng honda, i inquired at 10k ang oem nya,so far d pa ako nakakabili dahil ala pa budget.
    anyway, i was also confused kasi wala ako nakikitang tagas from the power steering pump pero nag babawas ang fluid, and may times na matigas ang manibela, just recently chineck ko yung ilalim ng carpet sa driver side kasi parang may nakita akong basa. there i found out na dun tumatagas ang fluid sa shaft where the steering wheel is connected.
    i dont know kung power steering gear box ang tawag dun or rack and pinion. i can only do minor troubleshooting but i dont really know much about engines, so i'd like to ask for your opinions po before ko ipa check yung car ko para nman di ako ma uto ng mga mekaniko. hehe.
    ---yung ganito po ba ay kaya pa ng overhaul?
    ---gear box po ba ito or rack and pinion assembly?
    --- ang repair kit po ba e set na for both steering gear box and rack and pinion or magkaiba yun? kasi may nabasa ako sa other thread na may kotse na rack and pinion type at may gear box type? tama po ba?
    your inputs are highly appreciated. thanks in advance
    Jun 2011
    #54
    Quote Originally Posted by LightFoot View Post
    palpak gawa nung TOTO sa kotse ko...nag bayad ako 3thou...tumutulo pa din...nagsayang lang ako pera...at muntik pa akong madisgrasya sa ginawa nila sa gulong ko...hindi nila hinigpitan yung nuts nung gulong...pag uwi ko sa bahay, 2 na lang ang natira...at sobrang luwag nung natira..umaalog na ang gulong ko...buti na lang,hindi natanggal yung gulong ko
    sir yung mga tropa ko dun kami lahat nagpapagawa so far so good naman... yung isang kasamahan ko more than a year na ps nya... ok parin po... baka na tyempo lang po yun... at dun pa nga dinadala ng ibang shop ang mga overhaul nilang p.s.... kahit saan shop may time talaga may back job... normal lang po yun kahit nga casa may back job...
    Apr 2009
    #55
    Hi nabasa ko lang itong thread regarding power steering leak.
    just recently lang kasi napansin ko may leak sa gearbox ng vehicle ko. Can you give me contact no. of TOTO?
    or kung may iba pang shop na magaling at hindi mahal maningil.
    thank you
    Jun 2011
    #56
    sir wala akong contack no. alam ko lang po puntahan... near corner E. Rodriguez po yun... sa harap ng dating PCSO OFFICE... IF galing kayong manila... pag nasa quezon ave... turn right at araneta ave.. then turn right at e. rodriguez then kung hindi sa unang kanto sa pangalawang corner... turn right near corner po sila... madaming nakahilera dun na gumagawa ng P.S. bandang gitna po yung toto... may warranty din sila... and you can also buy power steering fluid dun na color white banda dun sa area nila magtanong nalang po kayo... nasa 120 po lang per liter...
    Apr 2009
    #57
    thank you. punta ako one of these days if may budget na.
    okay lang ba pagtyagaan ko muna ride ko? leak niya siguro wala pa naman 1tsp a day. hindi ba ito delikado?
    Nov 2006
    #58
    Quote Originally Posted by speedyfix View Post
    hi, we don't overhaul steering racks since pabalik balik lang yung mga leaks. we can replace the rack with a surplus one and you can call the shop at the number in my sig for the estimate.
    thanks!
    Sir Migs. Pa advice naman.My FD is losing power steering fluid, kaya nag top up ako weekly. Malakas ang leak sa may rubber boot sa rack n pinion. Dinala ko sa casa , need daw remanufacture the gear box and 2 weeks daw ang downtime.
    How much ba pa repair sa inyo ng rack n pinion leak? Thanks.
    #59
    Quote Originally Posted by happymax06 View Post
    Dalhin mo sa benmawi motors sa biñan. Jan dinadala ng mga team fd peeps pag may problema sa power steering. Sanay na sila gumawa niyan
Need Advice on Power Steering Leak
