Results 1 to 6 of 6
    Jan 2012
    tanong ko lang mga master normal lang ba na pagpress ng brake pedal hanggang floor na inaabot ng brake pedal ko para kumagat yung preno. o dapat half press pa lang kumakagat na yung preno?
    May 2015
    Upod na po siguro brake pads mo sir. Or kung di man,check brake fluid or need mo ipa-adjust yan sir. Usually, ang half press medyo malakad na ang kagat.
    Consult a mechanic immediately sir, medyo maselan yang issue mo sir.
    Quote Originally Posted by justdiy View Post
    yup, its either upod o hindi gumagana yung brake master (hydraulics) mo. dapat nga yan pitik pitik lang.
    Check your brake fluid. Nagbabawas ba? If yes, may tagas ang brake system mo. If no, baka yung tagas sa loob ng master. Suggest you step on your brake then start the engine. Bumababa ba yung pedal? If not, brake master nga yan.
    Feb 2009
    Quote Originally Posted by basucat View Post
    The other responses are incorrect.
    The two possible causes are:
    1. The master cylinder has internal leak, (needs repair or replacement)
    2. The hydraulic system has air (needs to be bled)
    my bet would be #1 above.
Brake Pedal
