Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Aug 2006
    help mga tol... nakakainis kasi yung tunog, at the same time, may mga itim nanamumuo sa mags ko... nililinis ko sya madalas, then may nangingitim uli... mukhang dun yun galing sa brakes e... any idea what part ng brakes yun??? tnx... btw... disk brake sya, toyota gli, sa harap na gulong... tnx...
    Check your brake pads immediately!
    Pag hindi mo agapan baka madali rotor disk mo!
    Aug 2006
    brake pads yan hijo. nakapadelikado nyan sa buhay mo at ng mga kasakay mo.
    papalitan mo na kagad, mura lang naman yan. ipa-reface mo ren ang brake discs mo dahil mukhang marami nang nakain at siguradong di na pantay yan.
    isabay mo na ren ipa-check yung rear drums mo, malamang kelangan na i-adjust yan.
    Aug 2006
    yun nga yung iniisip ko and pinachek ko, makapal pa sya e... any more ideas??
    Mar 2005
    replacement or OEM ung brake pads? ung ibang replacement kc eh umiingay talaga khit makapal pa. bendix ckin eh ok. walang ingay. Nung iba nilagay kc out of stock ung bendix eh ang ingay. nakakainis. kailangang linisin/lihain palagi.
    have that checked immediately if you still have any pads remaining. and you might have damaged discs as well.
    also, there's also a slight chance na kaya maingay yan kasi:
    • Bendix yung replacement pad na kinabit (squeaky yung iba)
    • madumi
    Try to check the disk guard plate baka nabingkong or may stuck na bato.
    How is the condition of your rotor?
    When did you last replaced your pads?
    Nov 2003
    have the brakes inspected. sandali lang naman yun.
    since i got hold of my rav 04, as i start my car and move back squeeking sound is heard but after backing ok na, yung una lang weird, nothing seems to be wrong naman
    Jul 2006
    This irritating sound also bothers me.
    The thing is that all of my pads are still ok.
    I will try to clean it via sand paper and will give you guys feedback with the results.
    Nawa'y patnubayan tayo ng MAYKAPAL sa ating paglalakbay.
kumakaskas na tunog ng bakal sa brake kapag prumepreno...
