Results 1 to 10 of 35
June 15th, 2015 11:25 AM #1
up on this,
guys anong suspension ba ang 3" lift tapos ang priority mo is comfort? wala naman laging dalang mabigat minsan lang kapag nag grocery or out of town.
daily use yun sasakyan sa work.. so need ko sana yun comfort with 3" lift... planning to upgrade my tires din kasi after the 3" lift
TIA
up on this,
TIA
June 16th, 2015 10:21 AM #2
kung gusto mo malambot use PROCOMP, most aftermarket off-road are designed for added load capacity kaya medyo matigas, pero if you have the budget get the adjustable ranchos para you always have the best ranges of settings
June 16th, 2015 01:16 PM #4
sir miko, sorry noob question pero you mean po ba sa adjustable eh pwedeng soft pwedeng hard? or adjustable yun height?
nasa magkano po price range ng PROCOMP at ng RANCHOS sir? para may idea lang po...
thanks po :D
thanks po :D
June 16th, 2015 10:31 PM #5
adjustable siya in terms of softness or stiffness,,
procomp usually 2-4k each (es1000) , the ranchos pinaka mura 7K each, ito yung (rs9000xl)
the ranchos have 9 settings , 1 as being the most soft, 9 being the most hard.
so covered ka for every situation yun nga lang you have to bend down in order to dial/adjust the ride kasi the knob sits at the bottom of the shock...
June 16th, 2015 11:02 PM #6
okey pala yan sir, yan din po ba gamit nyo sir? san shop nyo po nabili at install pa pm naman sir :D
June 16th, 2015 11:08 PM #7
yes ito gamit ko ngayon. kahit meh karga ako na 500KGS sa likod eh kayang kaya ng rancho kahit setting 7.
pag 1 malambot naman, depende sa purpose at condition you will be into.
sa banawe madami nagtitindi pati sa internet, pero i bought mine sa L.V.C motorparts, sila pinaka mura dati eh. sabihin mo lang model mo para malaman kung meh available for your vehicle..
hindi ko lang alam if they install, kasi ako personally nagkabit nung akin.
pero most reputable shops can fit them. madami naman shops sa banawe basta yung meh pwesto/lifter at matino. clue ( doon ka pakabit sa mga nag oofer nang off-road upgrades)
June 16th, 2015 10:27 PM #8
mag two years na ako naka rancho. once a week nagkakarga ako nang 400 kilos. napaka ganda gamitin nang rancho.
yung number 1 setting ay talagang malambot, at yung 9 naman talagang walang galawan shocks mo.
considering na torsion bar ako sa harap at leaf springs and likod ko, ramdam mo ang effect pag nasa 1 lang setting.
i have already tried the ironman and procomp, pag ginamit mo sila off-road o kapag meh cargo ka mabigat they won't last long, masisira agad. usually at 3 years lang, sa rancho i think it will serve the life of the vehicle bago masira.Last edited by miko101130; June 16th, 2015 at 10:34 PM.
June 16th, 2015 10:59 PM #10
ahaha.. pang SUV lang naman rancho's eh....
tsaka kung abutin nang 10 years eh sulit ka na.
kumbaga eh "one shock to rule them all"
tsaka rancho Rs9000xl are the only TRI-tube shocks among all shocks...
other shocks nag gagayahan lang sa foam cell principle, separating the oil from the high pressure gas.
RS9000?XL Shock Absorbers - Rancho® Performance Suspension & Shocks
kung bulletproof sasakyan mo o sobrang bigat talaga nang load mo na tipong hindi ka na average vehicle or super modified ka then your only choice apart from rancho's would be the Australian "tough dog shocks" specifically the 53mm ralph model"...
53mm Ralph - Tough Dog 4WD Suspension
Tesla Philippines
