Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 98
    Feb 2014
    it's been 3 years since i last changed the brake fluid on the honda so i'll be replacing the fluid, change brake pads, and do general brake service
    what to use on the caliper pins that's locally available? i have PLAIN silicone grease lying around, is that ok? it doesn't have any moly or graphite additives it's just a thick plain silicone grease
    Mar 2005
    Quote Originally Posted by Vodka View Post
    Meron sachet ng Wurth caliper grease. Around 75 pesos nung Car show sa SMX sa Wurth Booth. Good for 4 calipers na. Nasa 100 pesos na siya sa Fix stop nung last na bumili ako. Before ang hirap talaga maka hanap umorder pa ko sa Amazon ng Permatex Ceramic caliper grease pero much better yung wurth.
    Feb 2014
    Quote Originally Posted by jmpet626 View Post
    thanks i'll look for that
    what does it look like? just translucent white like petroleum jelly?
    Feb 2012
    Caliper grease - yan ba yung para hindi mag-chatter yung brakes? Sa Concorde meron nyan. Nasa lata siya. Parang thermal grease (Arctic Silver) ng CPU heatsink ang hitsura.
    Sent from my LG-H962 using Tapatalk
    Still 75pesos per sachet. Found in some handyman stores. Nakakita ako sa handyman galleria.
    Feb 2014
    Quote Originally Posted by gearhead000 View Post
    the grease used behind the brake pads is different
    the wurth grease they're talking about goes into the slider pins. silicone so it won't hurt the rubber boots of the pins. i used to have a ford lynx w/ seized caliper because of neglecting the slider pins so lesson learned LOL
    wala tingi nito bro diba? magkano yung nasa can?
    san yung fix stop located?
    Feb 2014
    at True Value marquee (pampanga)
    Mar 2005
    Yung Fix Stop sa may congressional ave qc siya located. Gamit ko din to as anti rattle grease sa likod ng backplate ng brake pads. So far ok naman.
    ^thanks bro
Grease for brake caliper pins
