Results 1 to 10 of 34
    Feb 2017
    Hi sirs,
    Just had my 2012 Vios for 50k PMS and casa recommended to replace front lower arm (left & right). Sa Monday pa mabibigay sakin quotation but right now pa lang gusto ko na makakuha ideas and comparisons:
    1. Mga around how much if ako bibili ng replacement part?
    2. Any recommended shops na pwede na din mag-install? better if around laguna / alabang area if possible.
    Salamat po sa mga sasagot [emoji16]
    hanap ka ng bushing replacements and installer.
    example lng ito...
    imageupload
    Feb 2017
    example lng ito...
    imageupload
    Mga magkano kaya aabutin ng ganyan sir?
    no idea yet. i might do this on our vios also...
    Feb 2017
    Balitaan niyo ko sir if ever you are able to source parts. Worry ko kasi baka sobrang mahal ng i-quote ni casa [emoji28]
    Oct 2009
    kung may bibili per piece lang mas makakamura ka kung tig isa bushing lang sira saka mo ipapa press in & out ang bayad sa mga machine shop ng ganyan.pero may mga talyer naman na may press machine sila.
    Quote Originally Posted by terrajn View Post
    the casa will probably quote the entire assembly, which will cost you an arm and a leg.
    but if you have it done outside, and all they do is replace the rubbers, it should be considerably less.
    what i do not know, is whether the replacing the rubber only, will give a lasting fix.
    Hi sirs,
    bakit replacement agad? usually bushing lang ang pinapalitan.
    Apr 2009
    I'm not sure about the Vios, but in the case of the Altis, casa don't sell individual Bushings and that they are sold as "assembly" (A-arm with the small and big bushing already). Probably the same case with the Vios.. But if you can find a good third party bushing, it would also be more economical. Not sure if 3rd party parts offer Polyurethane bushings these days
    Quote Originally Posted by LN106G View Post
    may nakita nga ako iba bushing na medyo mas mahal. 800 php vs 40 php ordinary rubber.
    lahat ba ng gawa ng cruven, di na ma align after palitan ng tire rubber?
Front Lower Arm Replacement
